Looks to me as though the SB is a one piece and the PP is your choice of single piece or not.
Lets go to the source, I marked the differences in
bold/italics/underline/green.
https://www.andersonpower.com
http://www.andersonpower.com/us/en/products/sb-sb-boots/index.aspx
SB® Connectors -
up to 500 Amps
Genderless Housings
Low Resistance Connection
Hot Plugging AC or DC
Keyed & Color Coded Housings
Self Securing Design
http://www.andersonpower.com/us/en/products/powerpole/index.aspx
Powerpole® Connectors - up to 350 Amps
Genderless Housings
Stackable Modular Housings
Connection Versatility
Official Youtube channel for Andersonpower
https://www.youtube.com/channel/UC-ZE3mVmcS1ur0TjgJ0nF7w
Not many video's from Andersonpower.
There are countless other video's from other YT'ers showing installations.
The few video's I saw, I could not see how the conductor blade was attached inside the housing... for obvious reasons.
A final note, the one piece SB's do have an optional component of a cover when not in use, not sure if PP's have a cover.
Also to my eye there seems to be a different locking mechanism between the SB and PP. [strike]The SB looks to me, as though you could mechanically fasten both connectors together.[/strike] It has been confirmed here
http://www.andersonpower.com/_global-assets/downloads/pdf/ds-sb175.pdf
that for the SB's there is another option, a handle can be bolted to each connector.
945G3
(not included).
"A" Frame Handle
- 77 -
All Data Subject To Change Without Notice
| SB
175 ORDERING INFORMATION |
SB
175 Connectors
- up to 280 Amps
SB
175 Standard Housings
The second to largest SB
housings work with wire contacts up to 1/0
AWG [50 mm²] as well as busbar contacts. Genderless design mates with
itself. Mechanical keys are color coded. N
Cable Clamps
Durable metal cable clamps securely hold cables to prevent accidental strain or pulls from dislodging
wire or contacts from the housing. Only Bolt On type clamps can be used with the handles. Cable
clamps are recommended for solder terminated wires. Not for use with 3 pole housing.
Handles
Handles are made out of durable PC plastic. Hardware to
attach to connector body included in kits. Not for use with
3 pole housing.
Dust Cover
Prevents dust and dirt from entering the mating interface
of the connector when unmated. NOTE: Not a Hermetic Seal.
