NeedForSpeed
1 W
- Joined
- Dec 31, 2017
- Messages
- 64
There aren’t a ton of posts on mid-drives on an EEB frame, so I figured I’d share my project while it’s in progress.
Currently my setup consists of:
- EEB Frame
- Rockshox Domain RC Front Fork 27.5”
- 72v 20ah, 150amp continuous, custom battery build, using 18650 Samsung R25,
- Kelly KEB72601 controller
Previously I had a rear hub Crystalyte TC100, but the axle snapped, so I decided to go with a mid-drive next to avoid that kind of situation again, as it was pretty terrifying.
So far this is what I’m thinking of getting. I’d appreciate any feedback or comments based on others experiences.
20” BMX Rim - Stranger XXL (42mm) - not sure if 20” is a bit too small given the 27.5” in the front. I was struggling to find a 24” with everything else I was looking for. I was thinking worst case I can fit the front with a 26er. My thinking of going with the 20” was for better acceleration and the options available for beefy bmx rims, as well as that I’ve read they pair well with 16” moto tires.
https://www.sourcebmx.com/us/us/Stranger-XXL-Rim/m-29207.aspx
Hope Pro Boost hub - this was the only 36H disc hub I could find that was the width I was looking for (greater than 135), so it would fit solidly in my EEB frame dropouts (though I’ll need to do some work on widening them since they’re only 9mm at the moment)
https://www.jensonusa.com/Hope-Pro-4-148mm-Boost-Rear-Hub
16” Pirelli moped/motorcycle tire - My ride is filled with plenty of pot-holes, and I’m aiming for a nice feeling ride at higher speeds, so I was thinking of getting a moped tire.
https://www.amazon.com/Pirelli-ML-75-Moped-Tire/dp/B005T37ST4/ref=sr_1_1?ie=UTF8&qid=1538571133&sr=8-1&keywords=pirelli+ML+75
Chains
BMX TBD
Spokes
Calculations gave 180.6 Left, 178.5 right, so I'm going with 180 and 178.
Odyssey - https://shop.odysseybmx.com/collections/odyssey-spokes/products/hgs-spokes-silver
https://www.prowheelbuilder.com/spokelengthcalculator
attached images of the bike in its heyday.
- EEB Frame
Chains
BMX TBD
Spokes
