Is this amp meter for DC?
rg12   100 kW
Post by rg12 » Oct 07 2018 4:48am
https://www.ebay.com/itm/DC-Combo-Meter ... Sw-CpX-mN4
It has that clamp that goes over the wire which is usually AC, can that also be for DC?
Some other weird thing, it says self powered 12-120V DC or 7-32V DC
Why not just say 7-120V DC? what do they mean there?
eee291   100 kW
Re: Is this amp meter for DC?
Post by eee291 » Oct 07 2018 5:09am
It can measure and power itself from 7-32V. If you want to measure anything from 32-120V the thing needs to be powered separately. power supply to the device needs to be somewhere from 7V to 32V. That's my guess at least
rg12   100 kW
Post by rg12 » Oct 07 2018 7:55am
Oh ok then, but what about the dc/ac? can it measure dc with a clamp meter? it says up to 500A so I'm guessing it's ac?
torker   1 MW
Post by torker » Oct 07 2018 8:23am
Yes. Pretty sure it has to be true rms meter . I use Southwire meters. The true sine d.c. meter I have only reads to 40 amps .
Although that does run the wire through a "clamp". Can you message the seller?
Looks like has it for 35.00 looking at other products he sells.
Dave When I die I want to slide in sideways yelling WooHoo what a ride !
Giant Rincon w rear 9C 6*10 36 v x 20 amps
Specialized FSR Comp 9C 6*10 48v x 30 amps
rg12   100 kW
Post by rg12 » Oct 07 2018 9:04am
Will check thanks alot :)
dustNbone   10 kW
Post by dustNbone » Oct 07 2018 5:34pm
I'd assume it measures DC Amps, as it's sold as a battery monitor. There appears to be 2 voltage ranges, 7-32V or 12-120V, maybe there are 2 different models of the meter and you need to specify on ordering, or 2 input terminals you can connect to depending on application.
AFAIK DC "Clamp" meters use a hall effect sensor to measure current, I have a Fluke one that does this and it seems pretty accurate, but probably not as much so as a proper shunt.
