Emergency Disconnect Switch
artvk
Bangkok
Hi guys,
I would like to know where to buy well-designed disconnect switch that handle my e-motorcycle 72V.
I only see the one in attached photo from Aliexpress. Most of them from China quite big and not good looking.
Thanks in advance !!
They tend to be big and ugly because you needs a lot of switch to carry and, when needed, break the current of something like a motorcycle.
Many woud argue that, unlike a brushed motor, if you have a brushless system you don't need one, as long ss you have a keyswitch and brake cutouts in case the throttle becomes faulty. The controller itself should never fail in a manner that provides drive to the motor (i.e. Mosfet failure).
AFAIK though, commercial EVs use a contactor controlled by the keyswitch. Still big and ugly, but can be hidden away.
For a DIY solution you could use something like a big anderson powerpole connector with a handle. Place it where you can reach it and yank it to disconnect the battery.
That said, I am sceptical that on a runaway high powered motorcycle anyone would have the presence of mind and control to take one hand from the bars and fumble for a keyswitch or emergency disconnect. Brake cutouts would probably be most effective as you will naturally apply the brakes as a reflex.
Thanks
