Read a topic off-line
Rydon   100 W
Post by Rydon » Feb 08 2019 7:38pm
Is it possible to download a topic on Endless Sphere (a phpBB forum) to read offline? I have some airplane time coming up and need to peruse a topic that is over 100 pages.
neptronix   100 GW
Re: Read a topic off-line
Post by neptronix » Feb 08 2019 8:04pm
AFAIK, the forum gives you no options for doing this.
If you try to use winhttrack, you're probably going to end up with >100gb of data that consists of everything on the forum.
You could use a screenshot tool that captures the whole page, or the web browser's 'save page' function and manually save everything. A bit tedious, but it would work.
amberwolf   100 GW
Post by amberwolf » Feb 09 2019 1:58am
DTS, DownloadThisSite (which I think uses winhttrack?) can be used for that sort of thing. Might take you a few tries to get it to download all of a thread including pics but not anything else. It has uplevel and downlevel controls, so you *can* narrow it down...just odn't know if you can do it to just one thread.
Or you could download the whole site using it, and have all the threads at the current state, at least.
mark5   100 kW
Post by mark5 » Feb 09 2019 6:27pm
I haven't tried it but the wkhtmltopdf program is supposed to be able to render a webpage and write to pdf from a Windows, Mac, or Linux command-line. So assuming it works ok all you'd have to do is generate 100 urls like:
Code: Select all
https://endless-sphere.com/forums/viewtopic.php?f=<forum #>&t=<topic #>
https://endless-sphere.com/forums/viewtopic.php?f=<forum #>&t=<topic #>&start=25
https://endless-sphere.com/forums/viewtopic.php?f=<forum #>&t=<topic #>&start=2450
into a file and feed it to wkhtmltopdf.
What is the topic, Rydon?
ETA: tried it; looks ok. Output file attached.
topiclastpage.pdf
(734.6 KiB) Downloaded 37 times
neptronix   100 GW
Post by neptronix » Feb 09 2019 7:40pm
Suddenly i'm grateful for all the work i did to the CSS on this site. Otherwise this would look pretty bad in a PDF. It's not too bad!
I never considered that the site would be printed to PDF when tweaking the CSS, so that's a stroke of luck, lol.
