how do those "Pneumatic-Cylinder-Magnetic-Sensor-Reed-Switches" work?
izeman   10 GW
Post by izeman » Feb 11 2019 4:01pm
Bought two of those to use them as a reed switch for ebrakes in combination with a Cycle Analyst.
https://www.aliexpress.com/item/1PCS-CS ... 4c4dEOKtZP
Screenshot from 2019-02-11 22-00-18.png (16.42 KiB) Viewed 318 times
But it seems they are not to be used like "regular" reed switches. They may need some power? But how much? And how will it sense the switching?
I guess it is just not useable for my application?
Any advise someone?
Thanks!
fechter   100 GW
Re: how do those "Pneumatic-Cylinder-Magnetic-Sensor-Reed-Switches" work?
Post by fechter » Feb 11 2019 4:42pm
The specs look like a normal reed switch. It only has two wires. It does say 5v -240v AC or DC
Reed switch.jpg (7.22 KiB) Viewed 312 times
If you measure ohms across the wires, it should show continuity when you get a magnet close.
www.recumbents.com   10 kW
Post by www.recumbents.com » Feb 11 2019 4:46pm
Pass a magnet close by it and you should hear a little click.
izeman   10 GW
Post by izeman » Feb 12 2019 1:22am
That's what i was expecting. But it didn't work. It's a NO switch. And passing a magnet anywhere around it doesn't do anything. Will try a stronger magnet.
amberwolf   100 GW
Post by amberwolf » Feb 12 2019 1:29am
Maybe the wire is broken somewhere inside it's insulation?
maybe they're fake, just plastic with wires sticking out? ;)
izeman   10 GW
Post by izeman » Feb 12 2019 3:02am
I ordered two. And they look quite legit. And they were quite pricey as well. I will do some more testing.
Maybe they really need stronger magnets. I'm also wondering what that screw is for? Any ideas?
And does THIS make any sense to you:
Installation attention:
The quick connectors at the end of the line are all three needles, one male head, straight line and one rotatable screw tooth type, and must be ordered in addition to its matching inserts.
fechter   100 GW
Post by fechter » Feb 12 2019 9:06am
I think they are saying you have to terminate the wires yourself.
Some magnetic switches are polarity dependent, meaning the magnet direction matters.
No idea what the screw does, but you might try removing it and looking in the hole to get a clue. It might possibly change the sensitivity.
It also says something about a LED indicator. If the switch is NO, then the LED would be across the wires? This could be tested with a power supply.
izeman   10 GW
Post by izeman » Feb 12 2019 10:09am
Hmmm. Thinking about that. What puszzles me, is the LOAD mentioned on the sticker. There is no load. The CA is just checking for not/shorted. So it sends a 5V signal into the switch and checks the input pad for high/low afaik.
I'll take out the screw and then check with it directly connected to the CA.
Punx0r   10 GW
Post by Punx0r » Feb 14 2019 7:15pm
Not sure, but the presence of the LED indicates it would be polarity sensitive. That said, it'd be normal for these things to take 5VDC. It seems a little strange you could supposedly put 240V and not fry the LED (if not the switch contacts).
Here's how the magnets in a pneumatic cylinder work: https://www.hydraulicspneumatics.com/cy ... ositioning
izeman   10 GW
Post by izeman » Mar 04 2019 4:49am
Don't know what went wrong with my first tests. Those switches work as you expect it. Move a magnet close to them and they switch. Once it's closed, a super tiny LED turns red. Using them as an ebrake switch should work in case you can find a good location for the magnet as the sensing direction is mainly on the long side of the sensor, and not the ends. And the magnet has to be quite strong as well.
izeman   10 GW
Post by izeman » Mar 05 2019 3:54pm
Installation done. All working fine. I don't really like the magnet installation as it's not really clean, but it should work.
