2mm Polycarbonate vs. 3mm Acrylic
rg12   100 kW
Post by rg12 » Apr 30 2019 5:38am
Which is stronger/less likely to crack? (not for drilling)
24S 17.5Ah 25R, Greentime Controller, QS203 5KW
Rube   100 W
Re: 2mm Polycarbonate vs. 3mm Acrylic
Post by Rube » Apr 30 2019 6:08am
Polycarbonate, what do you intend to use it for? Keep in mind it's hygroscopic. Edit, just realised your comparison thickness varies so maybe the acrylic depending on the application.
rg12   100 kW
Post by rg12 » May 01 2019 9:18am
Rube wrote:
Apr 30 2019 6:08am
It will protect a battery pack with cell holders, sit flat on it, from experience heavy battery packs if not handled with super care make the 2mm acrylic crack from very light hits.
Bobw   10 mW
Post by Bobw » May 01 2019 1:19pm
Not sure exactly what you are planning to do around an enclosure, but 2mm acrylic would not make a very strong unit and might be subject to flexing and cracking as you thought it might.
I have some experience with using acrylic, I used 4mm to build the battery and controller box on my ebike. The battery itself is 96 18650 cells and there is additional weight with battery connectors. I wanted to use 6mm material but settled for 4mm when I found a half sheet for a good price. I’m going into the 3rd year of service on my bike and so far, no issues with the acrylic box. I used acrylic solvent to glue the joints together, the result is strong and light. I guess what I am saying is that if you choose to go with acrylic, use 4mm not 2mm.
Hope this helps.
fechter   100 GW
Post by fechter » May 01 2019 1:44pm
Polycarbonate is much more impact resistant. Also melts at a higher temperature. I've used it as an insulator in pack builds before.
MJSfoto1956   10 kW
Post by MJSfoto1956 » May 01 2019 2:25pm
I'm using 6mm "greenhouse glazing" for my battery box and spacers between banks (for ventilation). Lightweight and strong.
e.g. https://www.teksupply.com/contractor/su ... carbs.html
M
Only a few more days to vote!!!: viewtopic.php?f=26&t=102697
Слишком мало, слишком поздно
rg12   100 kW
Post by rg12 » May 01 2019 6:38pm
fechter wrote:
May 01 2019 1:44pm
I have a real space limitation where every millimeter counts so I need to know if a 2mm polycarbonate will be at least as strong as 3mm acrylic if not stronger.
fechter   100 GW
Post by fechter » May 01 2019 7:16pm
rg12 wrote:
May 01 2019 6:38pm
It's nearly unbreakable as long as it doesn't get exposed to certain chemicals, like diesel fuel or cutting oil. The stuff I'm using is 1/16", whatever that is in metric. You can hit it with a hammer and it won't crack. It should be very good in your application. Thin stuff you can cut with tin snips.
rg12   100 kW
Post by rg12 » May 02 2019 2:24am
fechter wrote:
May 01 2019 7:16pm
rg12 wrote:
May 01 2019 6:38pm
That is amazing!
fechter   100 GW
Post by fechter » May 02 2019 7:51am
A thick piece of polycarbonate will stop a bullet without cracking. Get some scraps and try breaking them.
