Kelly KLS8080-IPS Controller help
SPanna23   1 µW
Post by SPanna23 » Jul 18 2018 2:34am
Hi All,
I have the above controller connected to a ME1115 motor which uses a SinCos sensor on my motorcycle.
I can get the drive to do angle identification & have set the correct values for amplitude & zero crossing.
The motor runs when the rear wheel is off the round but under any kind of load it trips on Hall Error.
Anyone had similar experiences?
Ingo   10 mW
Re: Kelly KLS8080-IPS Controller help
Post by Ingo » Nov 30 2018 4:14pm
hi,
yes i have the same problems at the moment.
i think the problem is the sensor or the amplitude
Atrastin   1 µW
Post by Atrastin » Feb 11 2019 12:29pm
Hi,
Did you find a way to make the KLS work with ME1115? Any clue what the problem was? I'm also curious if someone has this combo and it works. I'm considering KLS14401-8080IPS with ME1115 on my motorcycle build.
