electric scooter - moped more top speed
matsh   1 W
1 W
Post by matsh » Dec 27 2019 4:27am
Hi guys.
i have a chinese electric moped. stock is max 45 km/h.
60v peak charged acid batterys. in the need for more speed.
i made a new battery pack at 80v peak charged and a new kelly controller KLS7230S.
i have a ton of torque if i go high in the settings. but the top speed is almost the same.. now i have 48-50km/h at top speed.
other electric motors i have worked with is simple. more voltage = more speed. not this hubmotor..
is this for real ? something wrong i have done or is this hubmotor limited at this speed ?
i have checked ewerything and all is correct and working like it should exept the top speed missing.
do i need to buy a new motor to have more speed ?
Dauntless   100 GW
Re: electric scooter - moped more top speed
Post by Dauntless » Dec 27 2019 3:59pm
I just think there's not enough info. Doesn't seem unreasonable the way it is, we'd probably need to know more to say anything meaningful.
What is the actual bike?
Any sufficiently advanced technology is INDISTINGUISHABLE FROM MAGIC!
- Arthur C. Clarke
matsh   1 W
1 W
Post by matsh » Dec 27 2019 5:01pm
Hi.
Here is a link to a shop in poland that sells this model.
https://www.trybeco.com/skutery-elektryczne/libra-1-5/
Sent fra min VOG-L29 via Tapatalk
Voltron   10 MW
Post by Voltron » Dec 27 2019 9:43pm
I'd double check your controller settings, like number of magnets, field weakening if you have that, throttle voltage range, etc. The higher voltage should be making more difference... Or maybe it's looking for a 3 speed switch to be hooked up?
amberwolf   100 GW
Post by amberwolf » Dec 27 2019 10:08pm
do the kellys have a 3speed switch option?
note that if the power available at the motor isn't much higher, the speed won't be muhc higher either, if it was already at the limit of how fast that power would push it against air resistance/etc.
If the kelly controller isn't set to a high enough current limit, it won't provide enough power to the motor to push you faster even if the motor can handle it.
matsh   1 W
1 W
Post by matsh » Dec 28 2019 3:14am
Its not the power its missing. I now have twice the acceleration than before. Ripps hard from start and stops at 48 - 50 kmh.
If speed was limited by power it should have bwen more Smoooth.
Kontroller has 3 speed option, but this is turned off. Have testet and adjusted max throtle voltage so controller is getting 100% throtle.
Dauntless   100 GW
Post by Dauntless » Dec 28 2019 4:29pm
Can't read Polish, seems like it's claiming both 500w and 1500w.
I wonder if you're just asking more than the little thing can offer.
- Arthur C. Clarke
Dui, ni shuo de dui   1 kW
Post by Dui, ni shuo de dui » Dec 30 2019 4:57am
That's weird. With this voltage and this wheel diameter, your moped should reach around 75-80 km/h.
I think there is something wrong in the way you've set up your controller.
Please post some screenshots of all the different tabs you see in the controller interface so we can help you diagnose what's going on.
Also, meanwhile, check the very basics:
-Are your brakes set up properly, don't they slow down the wheel while they should not?
-Are your wheel bearings ok?
-Don't you have excessive battery sag (when you reach full speed, what is the battery voltage)?
-Are your tires properly inflated?
I don't think those are the culprit, but I've seen it happen in some very rare cases so that's good to make sure.
My guess would be that you'll have to change the "Max Speed" setting. By default it should be set at 4000rpm, but you can move it way up, I think the actual limit is 15 000rpm.
:bolt: :bolt: My electric Ninja 250 clone: 16 000W 72V40Ah A123 cells : :bolt: :bolt:
https://endless-sphere.com/forums/viewt ... 12&t=90032
:bolt: :bolt: My electric Scooter: 11 000W 72V 50Ah LiFePO4 cells: :bolt: :bolt:
https://endless-sphere.com/forums/viewt ... 12&t=75912
