Sattva Ram said:
I am building an aprilia rs50 conversion and perfectly clueless as to what controller to buy. Svmc 72150, em150 and em 200 are the candidates.
I have no idea what this rated current, boost current, peak phase current and phase current protection means. I mean the kellys are at least straightforward peak and continuous is given. But I have no idea what the peak and continuous ratings are with these votols and sabvotons. Can someone translate these numbers to kelly language?
I can only talk about the Sabvoton since I don't know much about the Votol.
Usually Sabvoton will mention the battery current in the product's reference name.
For example, 72150, 72200, 72260, the last 3 figures represent the current that will be taken from your battery, provided the battery is capable of delivering it.
The 72200 Controller will be able to deliver around 450-500Amps per phase, while the 72150 can deliver 350 or so. I'm not sure how much amps the 260 can provide, I kinda forgot, I guess around 600. All of these should work fine on your bike, maybe the 72150 would be a tad weak though.
Battery current will roughly correspond to the "continuous current" on the Kellys, while phase current will correspond to their peak current rating. Its a bit simplified but that's the idea.
rated current: the actual power of your controller, how much it can deliver during all the acceleration time. That's the figure you can talk about when people ask you how much power your bike makes.
boost current: some controllers have a little switch, when you press on it the controller will give some extra current for a short amount of time. Kind of comparable as the NOS on racecars if you will. Kinda sucks IMO, I prefer to get a controller delivering all its power all the time, but some people like it.
phase current: the current that goes into your motor. This is not a really relevant figure to talk about your bike's power because it is not easily linked with voltage. Too high of a phase current for too long can destroy your motor, so it's good to know what your motor can take. Unfortunately, in most cases, you just can't really know so that's mostly a trial and error process...
phase current protection meant that the controller will cut off if, for any reason, the motor asks for more than whatever this figure is.
