flippy wrote: ↑Apr 08 2021 1:41pm
drone engines are NOT the same as a full on 5ft wide prop on a plane. the forces are immense. and a plane carries meat bags, drones dont.
The forces in airplanes have a way of being surprisingly non-intuitive. The thrust forces are not immense, and in fact they are surprisingly small. (See below.)
The main forces the bearings have to resist are the gyroscopic forces which arise when the plane changes direction, esp. if there is sharp turbulence. In a direct drive setup, these forces are by far the dominant forces on the shaft bearings. Once we spec the bearings to survive these, the axial thrust force is just a few percent additional load. The calculations are straightforward and published on bearing websites.
and most drones have deep groove ball bearings, those can handle -some- axial loads. still, drones have very low runtimes so bearing life is generally longer then most other things on a drone as they usually end up crashed before the bearings give up.
and your petrol engine HAS axial bearings. every ICE motor has them. you just probably missed them as they are often integrated on a surface.
I think it's important to not confuse plain bearings with deep-groove ball bearings. You're right that four-stroke engines typically have plain bearings( specifically journal bearings) and these cannot resist axial forces. As a result, the engines must have a thrust bearing (as shown in the photo). However, the two-stroke powerplant which carries this meatbag up uses ball bearings only. When I tore the entire unit down last summer I replaced them so I'd consider myself familiar with the subject.
I also disagree that drones necessarily have short lifetimes. Consumer drones perhaps do, but the larger scale ones, such as we built, were tested for thousands of hours. (We had a non-stop two-week long flight of our tethered drone.) My Joby JM-1, with its roller ball bearings, was developed for both drones and full-scale, and is currently being used for manned aviation tests.
flippy wrote: ↑Apr 09 2021 6:58am
a 10kW power output will roughly generate 800~1000 newtons of thrust with a good prop.
I am not aware of any airplane prop which can make that much thrust with that little power.
- My 18.3kW engine (two ball bearings) with a 46.5 x 35" wooden GSC prop makes 600N of static thrust.
- My 16kW Geiger motor (two ball bearings) with a 55" x 30" carbon-fiber Magcad prop will make 600N of static thrust.
- My 8kW T-motor U15-II (two ball bearings) makes 150N static thrust.
- My Emrax 188 (never disassembled so don't have firsthand experience with the bearings) could make that much thrust, but it's a 52kW motor.
Maybe if you played around with ecalc.ch you could find a 10kW motor with prop which could produce that much static thrust-- although I am somewhat doubtful--, however the prop would be so flat as to be completely impractical in forward flight. It's useful to know that somewhere around 67% pitch vs diameter the prop will be stalled in a full-speed static test and so there is a sharp upper limit on how much static thrust we can get out of a prop designed to provide high dynamic thrust.
how do you think a bearing desinged for radial loads and -some- axial loads will survive the loads a propellor and the axial force of pulling a plane will last? dont you think putting on a axial bearing to take those forces might not at least be prudent?
Adding the axial bearing can actually make things worse, especially with alignment. It could pull the roller bearings out of alignment or force them to bear the opposite thrust load.
Sometimes you'll see angular contact bearings in motor drawings, but I personally have yet to see one in the wild.
