Hey team, I'm about to start on a project to convert an motorcycle into electric.
In the past I've made an 52V E-Bike, but that was very much plug and play, so I'm looking for some advise and critique on my plans.
For context I live in New Zealand and currently drive a 650cc motorcycle
The goal/purpose of this build is: to build a fun/fast street legal city commuter that can handle cruising at ~100km/h for short periods but mostly stop start riding at 50km/h
Donor bike
I'm looking at using a KTM Duke 2016 200cc
The specific one I'm looking at is currently street legal, however after the conversion I'd need to take it through compliance, which i've been reading this document: https://www.lvvta.org.nz/documents/standards/LVVTA_STD_Electric_and_Hybrid_Vehicles.pdf
Which appears simple enough for the most part, I'm just not confidant in this area, any advise on ensuring it's able to be made street legal would be appciated
The other concern with this bike, is if the frame is strong enough for the motor. I'm not looking at using it's full power all the time, but I don't want it to fall apart when I do give it some juice.
From the googling I've done, it looks like the frame on this bike is the same frame as the same bike in a 390cc variant, which would indicate it's able to handle a bit of load, so could be alright?
Battery Pack
I'm looking at making a 26S 20P 18650 pack, fused at 300A (or maybe 200A - see below)
To make this I've found someone selling recycled P26A cells that are all >2500mah capacity at a good price
I plan on using the 0.1mm copper + 0.1mm nickel plated steel sandwich method mentioned on this forum
A few small things im not sure about here:
What connector to use for the batter pack? I've seen Anderson 175A mentioned, is that enough? there's also 350A but it required 1g AWG, which feels like overkill?
What AWG wire to use? I've seen some people say 6 or 4, but still unsure
Then the big one I'm not sure about here is the BMS.
I have found a 26S 200A BMS: https://www.aliexpress.com/item/4000206471196.html which would be easy to work with, but means the motor cant deliver it's full power, which required 250A.
So to hit 250A I found https://www.aliexpress.com/item/32997552090.html which has a 7-16S 300A variant, which would allow the motor to run to it's peak if I ran two of these (13S) in series
However, I'm finding conflicting information for wiring to battery modules with BMS in series, I've read on here about needing diodes in between the packs, but then I cant find any diodes that appear to be able to handle 300A and other people say they're not needed
Also how do you charge a 2x13S pack? can you use a 26s charger (109.2V) charger and then just charge them in series?
Motor
I'm looking at a QS 273 8kW 96 hub motor paired with SIAYQ96260 (96V 260A) motor controller
I've sent off an inquiry to QS Motors about this and a few other items and they've quoted this motor as having a top speed to 130 kph, max power at 23602W, max current at 254A, which I wont be able to hit with the single BMS approach, but dual battery modules would allow the motor to pull it's full current here.
Other parts that I plan on putting in:
- Main contactor
- Inertia switch
- Throttle with lighting control switches
- Rear disk break
Donor bike
Battery Pack
Motor
- Main contactor
- Inertia switch
- Rear disk break
