Does anyone know this controller
Albie72   100 mW
Post by Albie72 » Nov 21 2021 10:24pm
This controller came with my motorcycle does anyone know anything about it and is it programable thanks
j bjork   100 kW
Re: Does anyone know this controller
Post by j bjork » Nov 22 2021 3:02am
Looks like a "far driver"
viewtopic.php?f=30&t=112177
dolfff   1 µW
Post by dolfff » Nov 22 2021 5:59am
I let google translate play with the sticker. And indeed "Nanjing Far driver" came up. So that must be it.
dominik h   10 W
Post by dominik h » Nov 22 2021 6:18am
Fardriver ND72360
1). Controller Typ: Sinus Welle FOC Controller
2). Modellnummer: ND72360
3). Max. Bus Current: 150A
4). Max. Phase Current: 400A
5). Temp Sensor: KTY83-122
6). Working Voltage: 48V/60V/72V, max. 88V
7). suitable Motor : 2000W-3000W
8). 189mm * 121mm * 63,5mm
9). Wheight : 2,05 KG
Albie72   100 mW
Post by Albie72 » Nov 22 2021 7:29am
Thanks for the help is it a good controller I just wish I had a better 0 to 60 it's a little sluggish off the line
dominik h   10 W
Post by dominik h » Nov 22 2021 1:56pm
For fast acceleration you need either a light scooter and a light driver or more phase Amps.
I just ordered a ND96850 for my 180kg scooter., to get it faster off the line.
Albie72   100 mW
Post by Albie72 » Nov 22 2021 8:35pm
I have a full size motorcycle weight is 250 pounds
Albie72   100 mW
Post by Albie72 » Nov 23 2021 7:30am
Fardriver told me I should have a 721200 controller the one I have is for a 3000w motor...but he said I won't feel a difference, my question is if the motorcycle is working with the stock controller why buy a new one if I'm not going to feel a difference
dominik h   10 W
Post by dominik h » Nov 23 2021 2:08pm
If your motor and your battery can cope with a bigger controller you will feel a difference.
Tell us a bit more about your motor, your battery and your motorcycle.
Albie72   100 mW
Post by Albie72 » Nov 25 2021 6:22am
Here's some pics it's a full size motorcycle
Albie72   100 mW
Post by Albie72 » Nov 25 2021 6:24am
Another pic
dominik h   10 W
Post by dominik h » Nov 25 2021 6:34am
The controller is programmable, but you need a Bluetooth dongle or a PC interface.
The BT software can be downloaded at Siycosys , Link underneath.
http://www.siaecosys.com/list/?spm=a2g0 ... =21&page=2
If your motor ist rated for 10000W continous then you need a bigger controller.
Do you know what battery is inside and for what power it is rated?
Albie72   100 mW
Post by Albie72 » Nov 25 2021 7:51am
The company told me 72v 80amp the bike runs along time before charging
Albie72   100 mW
Post by Albie72 » Nov 25 2021 7:52am
Fardriver said I should buy a 721200 controller
dominik h   10 W
Post by dominik h » Nov 25 2021 12:07pm
Try to find out if your Motor is rated 10000w continous or peak.
If it is 10kW continous then you must find out how much amps your battery and the bms can supply.
Perhaps your battery is the limiting factor for a big controller.
The 721200 is big and expensive.
You must also find a place for it.
I would only buy it if the rest is strong enough for it.
If the 721200 does not fit , the 72800 has the same size as yours and has double the power.
Albie72   100 mW
Post by Albie72 » Nov 25 2021 8:39pm
Where I live no one knows anything about these motorcycle. If I get the controller u say and I dont have what the motorcycle supposed to come with will it still work.. thanks for ur help to
Albie72   100 mW
Post by Albie72 » Nov 25 2021 8:52pm
Also I will like to get a 72v 120amp lithium one day or hook up a 20amp for a back up I have enough of room
dominik h   10 W
Post by dominik h » Nov 26 2021 3:09am
I would start with the bluetooth adapter and your existing controller.
Have a look what is set in your controller.
The suplier of the bikes hould know what is inside.
You have to set/program the new controller, but you can always set it with the same values as your existing controler which should give you the same performance, if your battery will not give you more amps.
Albie72   100 mW
Post by Albie72 » Nov 26 2021 5:34am
Ill order the blue tooth Thank u for your help
