Help wanted on brandless em-100 Controller
_AMR_
Bussum, Netherlands
Hello all.
I purchased a 60v/72v sine wave 80A 3000W controller on Aliexpress.
It is basically brandless, but looks alot like the sabvoton ml7260 as it has the same measurements and looks. http://www.sabvoton.net/static/upload/image/20191016/1571209852610975.jpg
On the sticker it says EM-100
They seem to be sold widely on ebay- amazon etc etc.
The issue is that there are no learning wires on the device. I hooked the controller up correctly, but all I see is a red flashing LED on the back. It came with no manual whatsoever. The seller refuses to help me out as the 15 days claim period has expired.
There is a rubber cab on the device where an 8-pin din female plug is missing. I assume this is for programming.
Does anyone have directions for me to get this thing put in use?
Kind regards,
Alexander
Best bet is to look at these threads
https://endless-sphere.com/forums/search.php?keywords=votol&terms=all&author=&sc=1&sf=titleonly&sr=topics&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
about Votol controllers to see if any existing info will help. Most likely you'll need to either get the programming cable/software (if yours has a place to connect one), and set up the controller from your computer (or the phone app if it has bluetooth), or you'll need to go thru the full hall/phase combo wiring test to find the right combination for your specific motor.
https://endless-sphere.com/forums/viewtopic.php?f=16&t=3484
https://endless-sphere.com/forums/viewtopic.php?t=32455
etc
Thanks AmberWolf.
I checked the threads. My controller has 3 rows of pins on the largest of the two connectors, exactly like in this picture http://www.sabvoton.net/ml/ml7260.html
As far as I could find Votol EM controllers have only 2 rows of pins but then again mostly three connectors.
Do those EM controllers come with learning wires you have to use to setup the controller for initial use; to get the correct forewords movement of the BLDC? Mine has two pairs of them, green and white but they are labeled in Chinese for soft/hard start and 60v/72v
https://imgur.com/a/g6lLaE8
Come to think of it now: Could that blue connector be for programming?
hi , sorry if i'm replying in wrong way, but i'm using the same controller from last 6 months and it's a great controller , there is no self learning wire, it automatically pairs with the motor, red led is always blinking (as long as i know it don't show anything more than just powered on status.
for wiring, these stupid seller share one type of pic , but they comes with different color of wires with each controller, i figured out mine with the following photos, and some with trial and error.
overall this controller is silent, very good torque and can reach 85-90Amps, best thing is if phase wires short out, it doesn't blow any mosfet, happened to me twice.
i'm searching for a way to connect it to pc and enable regen somehow, as this controller doesn't come with, and internally it's almost the same as real EM-100, only difference i have noticed is that real one have 16 mosfets and this one has 12 mosfets.
if you found a way to connect it to pc or enabled regen, plz share it here as well, thank you.
ATTACH]
_AMR_ said:
Hello all.
Kind regards,
Alexander
