ZERO XU 2013 to 50hp ZERO FX conversion
Doctorbass
Quebec, Canada East
Hello guys,
New project starting: converting a old 2013 Zero XU to a FX with 50hp on it. :D
POWERTRAIN:
I plan running it on 72V just like my Sur ron X and using aASI BAC8000 controller capable of 90V max and 860phase amp.
I will rewind the motor to match the 72V by reducing the number of turns per tooth of the stator and will add more strands per tooth for higher current handling. Overall it should have about the same copper fill.
WHEELS
That FX will still run 16" rear tire and 19" front,
SHOCKS
The front suspension will come from an FX as well
The rear shock will be replaced by a performance FOX.
FRAME
I have checked and both XU and FX seem to have the same frame ans swing arm.
More to come!
Doc
Stoked for it my friend! You have plenty of all the skills needed!
