frostnova37
Hello,
I have been wanting to start a conversion project for a while now and recently managed to pick up a suitable donor at a decent price.
The previous owner had the top end blow out mid 2019, he put the registration on hold with plans to rebuild the engine. A few years passed and decided to move it on.
All cleaned up and ready for the fun part.
New Zealand has some regulations around EV conversions, one of which is that the final weight cannot exceed the 'manufacturers gross vehicle mass' without recertification becoming a headache. Out of the factory a (wet) DRZ 400 SM weighs 146 kg / 321 lbs, stripped back my 2016 model weighs 82 kg / 185 lbs. There is still some weight loss to go once I take a grinder to it but at this stage its looking like a 64kg / 141 lb allowance for the new electric drivetrain.
The intent/purpose of this build is to have an electric motorcycle suitable for low distance, daily on road use. These are my existing and ideal parameters.
Conditions:
-Low to no wind.
-Sealed roads.
-Daily use would be ≤10km / 6.2 miles at a stretch, I live very close to work so range is not a driving factor.
-Overall flat terrain, no notable inclines.
-Around town riding so a moderate amount of stop/starts.
Vehicle:
-Bike and rider combined will be ≤220 kg / 485 lbs (Assuming the weight is kept close to the manufacturers GVM).
-Capable of 115-120km/h with majority of the riding being done between 50-70km/h.
-17 inch wheel (motor will dictate gear ratio).
-12v system for lights/signals.
-Budget is flexible but living in NZ means that accessing parts takes longer and is more expensive.
At this point I'm looking at 3 potential candidates for motors:
QS 138 70h v3 (w/ reducer) - 3000W
-Easiest bolt in solution.
-Marginally more expensive than the 90h.
-Very popular, lots of community support/advice.
-Lowest footprint.
QS 138 90h - 4000W
-Requires 2 stage reduction (personal preference).
-Cheapest off of the shelf.
-Seems like the safe middle of the road pick.
QS 180 90h - 8000W
-Also requires 2 stage reduction.
-Nearly twice as heavy as the others.
-Twice as expensive.
-Not limited to 72v.
Majority of the builds here that use one of these three motors are dirtbike conversions and have what I would call 'limited' traction by comparison. Am I over egging it by considering a 8000W mid drive? The way I see it I would be pushing the 3000W to its upper limit to meet my needs but my opinion is far from informed. I am also interested in seeing some other before and after conversion weights to see where I stand.
I will be following up with a build thread once I have the motor, controller and battery locked in.
Conditions:
-Low to no wind.
-Sealed roads.
Vehicle:
-Lowest footprint.
QS 138 90h - 4000W
QS 180 90h - 8000W
