how to program a sevcon gen4
jenwu   1 µW
Re: how to program a sevcon gen4
Post by jenwu » Dec 05 2017 11:47am
Hi,
I'm doing torque control on a BLDC motor. I have some problems with getting the torque over 10 Nm. It seems like I can't get more than 50A, actual AC current (Iq,) even though I set the max amps to 100A. And the max torque is 100Nm. I'm using a battery bank, 84V, that should be able to drain a lot more. Is there some setting in DVT that I've missed to change?
Thanks!
bernext   100 µW
100 µW
Post by bernext » Apr 24 2018 4:29pm
frodus wrote:
Dec 08 2015 4:11pm
updating the thread, since people can't figure it out after things moved on the Heinzmann site
Go here:
http://www.heinzmann.com/en/download-el ... s-software
Then navigate the tree to "Motor Controllers", then "Software" then "Sevcon Software" and click on "Sevcon Install".
You will need to login with
Username : software
Password : perm-motor2010
Hi Frodus,
Is there any chance you might have an updated username and password for the heinzmann site? Those ones posted in 2015 are no longer valid.
Regards.
frodus   10 kW
Post by frodus » Apr 27 2018 6:29pm
I don't.
Basically, unless you have an OLD IXXAT cable, it won't work with that software anyway. I sell licenses and programmers at my site if you need one.
Arlo1   100 GW
Post by Arlo1 » Apr 27 2018 6:34pm
frodus wrote:
Apr 27 2018 6:29pm
I don't.
Is it possible to get that software anymore? I have an old cable.
My Leaf motor controller build. http://endless-sphere.com/forums/viewto ... 27#p963227
My YSR build http://www.youtube.com/watch?v=BRo8r5g4NBg
RC and most types of Lithium batteries you MUST know your individual cell voltages charging and discharging.
Don't keep them were you cant afford smoke or fire!
Support me on Patreon. https://www.patreon.com/user/posts?u=6842045
http://www.undergroundelectrics.ca/
golas429   1 µW
Post by golas429 » May 03 2018 9:31am
Hi,
I've been trying to program the Sevcon for a while, now it doesn't allow me to save a DCF or send a working DCF to unit. I've updated the firmware and still nothing. It says the Local Line contactor not mapped and Data type(15) for 4617, 1 unrecognised.
Has anyone encountered this issue, also when i try to save the current DCF it crashes.
Kind regards,
Gonçalo Olas
