E-max 110s lifepo4 upgrade
flexy   100 W
Re: E-max 110s lifepo4 upgrade
Post by flexy » Jul 26 2013 4:22pm
it's a very expensive piece of equipment, that's why most of us don't use sevcon. Your best hopes are with a Vectrix or e-max dealer, whereabouts are you?
72V Crooza scooter, converted to lifepo4 24AH 24S2P Headway, Lyen 18FET controller, 47mph
72V E-max 110S converted to lifepo4 A123 100AH 24S5P, Sabvoton 72150 controller, 49mph
dutchlincoln   100 W
Post by dutchlincoln » Jul 26 2013 4:33pm
Netherlands, Zoetermeer.
So, a programmer is "all" i need?
At work, we have a company that services our pallet trucks, and they use Sevcon. I KNOW he has a programmer, as he can adjust speed, current, ramp, braking, etcetera.
So the main question would be: Does it need specific software?
Or can we hook up the programmer, and just program it?
I figure, we kneed to know exactly what id's and bus numbers there have to be programmed? Everything is connected, brake lights, signal lights, speedo, etcetera.
How does this work?
I am promised to get the correct software from someone.. Just don't have the equipment to program it...
whereswally606   100 kW
Post by whereswally606 » Jul 27 2013 3:29pm
I have a programming tool, bought it from a chap who used to work for vectrix in the UK. Also as an aside I am a programmer but the two things are unrelated. Anyway one of these days ill work out a way to create a programmer from a cheap arduino by capturing code from this programming tool I've got.
Distributing "Lebowski" FOC Controller PCB (Through hole) since 2016
Moped: Emax 110s 2009
dutchlincoln   100 W
Post by dutchlincoln » Jul 27 2013 3:35pm
So, you cold program it for me?
Can you PM me where you live?
thanks.
Post by whereswally606 » Jul 27 2013 7:25pm
I live near Manchester in the UK. I have not yet programmed my two controller from vectrix / emax / proud eagle types. I guess you would have to send me your controller but before you do I had better learn how to do it and work out a cost of sending.
flexy   100 W
Post by flexy » Aug 04 2013 11:56am
I want to replace the oil in my forks, does anyone know how much is needed in each fork?
jonescg   1 GW
1 GW
Post by jonescg » Aug 05 2013 8:16pm
Drain it into a measuring cylinder and there's your answer... :?
dutchlincoln   100 W
Post by dutchlincoln » Aug 10 2013 9:59am
Wally,
I meant the Sevcon gen4 controller. As far as i know, the proud eagle is the earlyer controller?
Can we work out a way to get my vectrix up and running again?
I do have a usb-to-can converter, but never used it yet. (i got it with my MOTEC car ECU, its a motec piece of equipment, and i figure its a universal CAN programmer...)
Post by whereswally606 » Aug 11 2013 12:28am
No experience/ tools to mend/reprogram sevcons I guessing someone else on here has. I'd personally search for threads with your fave search engine and if none are found make a shout for help specific to the sevcon .
athlon   100 mW
Post by athlon » Aug 17 2013 3:34pm
on my E-max I changed fro Lead acid to 16 prismatic GBS 100Ah cell , they fit perfectly in the front part of the battery space
flexy   100 W
Post by flexy » Aug 18 2013 3:47pm
Hi Athlon,
Is that running at 48V with the original controller and what range do you get?
jonescg   1 GW
1 GW
Post by jonescg » Aug 19 2013 7:58am
Hey all,
Danny Potts and I were racing our E-max scooters at the Wanneroo Kart track on Sunday. They are running 16s3p A123 packs (built by Cell_Man back in 2010) and the controllers are dialled up for max take off power. Unfortunately we top out at 65 km/h, and only more volts would cure that. I think the Sevcons are limited to 63 V so perhaps 15s LiPo would work :D. Danny had about 10 psi more tyre pressure than me - we were mixing it up to see what worked and what didn't.
Shit-ton of fun. I'm in his way for the first lap but he sneaks in after I run wide. What do you know - more pressure means you go faster :lol: He does 60 second laps of Barbs on his R6, which is pretty f'n quick. I might get him to pilot my race bike next year.
flexy   100 W
Post by flexy » Aug 19 2013 3:22pm
Great video, JonesCG :D were those 50CC gas bikes you were up against?
I think more voltage + field weakening is the best way to get more speed out of these, those sabvoton controllers have it http://endless-sphere.com/forums/viewto ... ct#p761726 , the 6KW one might work well, I'm hoping they will bring out some bigger ones in the near future. I need to sort my suspension out before I get more speed, tendency to skitter on corners!
I did ask a suspension expert about the rear shock, he said it was way to strong for the weight of the bike, but maybe all that weight in the hub motor means you have to compromise with a harder spring.
athlon   100 mW
Post by athlon » Aug 21 2013 3:46pm
flexy wrote:Hi Athlon,
depends on driving style , anyway I did some times this road and arrived to Lugano with 35% battery left ( according to Elipowersolution BMS)
https://maps.google.com/maps?saddr=Mila ... v&t=m&z=12
of course I was very light on throttle because there are not recharge point in the middle so I have to reach destination
the scooter is a 120S , the controller is tuned for lead batteries , this mean that speed is limited to 70 Km/h , E-max 120L with lithium are limited to 80 Km/h
John in CR   100 GW
Post by John in CR » Oct 28 2013 12:44pm
Jonescg,
I just caught the video. OMG, racing slow mopeds...sure you can do it and have fun, but it's like riding a fat girl. You don't go around telling people, and you don't make video evidence either. :lol:
Tommy L   100 kW
Post by Tommy L » Oct 30 2013 5:57am
John in CR wrote:Jonescg,
LMAO! woooooot!
Nice!
Tommy L sends.....Image
http://www.rawvelocity.com
- 4th Hoolagan FS Mtn 9C-2810 with 128v nom 9.2ah A123 40S40P(1.2Kw) - Lyen 18Fet 4115 - 77.8kph :)
http://endless-sphere.com/forums/viewto ... =4&t=39480
- 3rd Catrike 700 Bionx PL350 Velo build
http://www.youtube.com/watch?v=rYdnkaAhVtI
- 2nd 150lbs Pusher Trailer
http://www.youtube.com/watch?v=Q1qTc4sjORY
- 1st Sears NS mtn bike - Rigid 10a drill 800rpm - 2 12v AGM - 1000 watt inverter - 600w dimmer for throttle, wicked torque!
48.2mph/77.8kph Club
RedKing73   10 µW
10 µW
Post by RedKing73 » Dec 18 2013 12:46pm
Hi,
sorry for cross-posting. I am attempting to disassemble my e-max 110S. All parts will be for sale. Here or eBay.
Does anyone know if I must take out all of the batteries before I can remove the controller?
On that note, does anyone have access to disassembly schematics? I am reading on http://www.vehiculeselectriques.fr and my French is not bad. But when I mix vehicle electrics and my 3rd language, it is difficult. Very difficult!
RedKing73   10 µW
10 µW
Post by RedKing73 » Jan 02 2014 10:52am
Hi,
Happy New Year everyone.
Can anyone advise on the most straightforward way to remove the controller from the e-max 110s? I have purchased offset screwdrivers but am still having difficulty getting at some of the screws. I have removed the black battery compartment cover in order to give me some more room.
Do I need to remove all of the batteries in order to remove the controller? Or how do you guys do it?
(I am stripping a 2008 hardly used e-max and have a for sale thread elsewhere :) )
Any help would be really appreciated.
Kind rgds
yokneamcity   1 W
1 W
Post by yokneamcity » Jan 02 2014 12:46pm
What bolts exactly do you mean?
You can make a picture?
RedKing73   10 µW
10 µW
Post by RedKing73 » Jan 03 2014 8:37am
yokneamcity wrote:What bolts exactly do you mean?
The 6 screws underneath the seat compartment and over the battery compartment. They hold the controller in place. 3 are easily accessible. 3 are not so easy. For me anyway.
yokneamcity   1 W
1 W
Post by yokneamcity » Jan 03 2014 9:59am
RedKing73   10 µW
10 µW
Post by RedKing73 » Jan 03 2014 12:19pm
yokneamcity wrote:You can make a picture?
Not at the moment unfortunately. I am away from it for a few days.
I mean the only screws / bolts that hold the OEM controller in place. To unattach it, these 6 star screws / bolts must be released. Also of course the power cables held in by allen key / hex nuts (under the seat).
I mean from outside the bike. Right underneath, where the controller gets air-cooled.
costicuta2000   1 mW
Post by costicuta2000 » Jan 28 2014 9:44am
Hello. I have a question guys. Did you know if the speedo can work on 84V?
Thanks
E-max 120L sevcon 15s li-mn. 80 km speed
Emax 90S modified to 72V 4,5kw kelly. Speed 73km/h 24S Lifepo4 pack
E-bike Bh Nitro stock configuration 45km/h
http://www.elvelor.fr
yokneamcity   1 W
1 W
Post by yokneamcity » Jan 28 2014 1:17pm
costicuta2000 wrote:Hello. I have a question guys. Did you know if the speedo can work on 84V?
Thanks
I think it's not worth trying for more than 60 volts.
costicuta2000   1 mW
Post by costicuta2000 » Jan 28 2014 8:06pm
Ok, thanks. I had found something nice.
http://www.ebay.com/itm/161183957855?ss ... 1439.l2649
the same screen size.
