Hey all! New to the Lipo scene, over a year ago I installed the Headway LiFEPO4 cells with Chargery DB8 into my scooter. All was well for a couple months, then I went on vacation and all the cells had settle below the safe voltage threshold and I had tried reviving them but failed. So for the past year, I've had an e-scooter sitting in front of my TV to remind me to get this eyesore fixed, and only recently had Dragonfire on GPN informed me of the lipo 7s setup and how it's ideal for these scooters with their controllers, I'm willing to take a chance!
But before I do I would love to run my thoughts on this setup by the rest of you guys with all your experience. I probably only got about 30-40 cycles out of the LiFEPO4 setup, and do not want to drop that much cash into a similar setup. Looking to get a minimum of 300 cycles, if not more .
Plan is to purchase 4x ZIPPY Compact 5000mAh 7S 25C Lipo Packs
Discharge check, trying to get 1/4 of the discharge rating of the pack to extend cell life.
5000 x 25C = 125A constant draw
125A x 4 packs = 500A constant draw
500A x .25 = 125A continuous draw from all 4 packs.
s
Now comes the tricky part. I've heard that it's possible to charge the batteries using the stock controller, but can't verify this since GPN's forum database won't connect for the past few days so it's still a mystery to me whether this is doable.
One thought I had was to purchase 4 of http://hobbyking.com/hobbyking/store/__7523__Turnigy_Accucel_8_150W_7A_Balancer_Charger.html to leave in the scooter and keep each one balanced 4 toggle switches on the outside to shut them off when not charging, to stop them from draining cells when not in use.
But I have (2) Chargery DB8's (pretty sure both work, know one works anyway) that I was thinking of running both inside the battery pan, parallel connections 2 packs per DB8 bms.
I've got an external charger, think it's a 7A if I remember correctly (at work sorry!) that I was thinking of using in conjunction with the DB8(s).
I'd love to somehow incorporate a LVC so that when the pack drains to say 30%, the pack cuts the power, or at minimum sends out a loud audible buzzer. I've got an old CellLog 8s that would be sweet to use for this, but other ideas would be welcome as well. Cutting power to the pack now that I think about it would be a bad thing, since the other 3 packs would have to take up the load, decreasing their C-rating by 1/4. Argh.
So the questions that nag now are the following:
1.) Is it true that with the Zippy packs you should halve the C-rating? If that's the case I'd have to double this setup and get x8 packs right?
2.) Would it be better for the batteries to be charged using the main leads or the balancing leads sending the power through a balancer?
3.) Is it better to balance the 4 packs individually or parallel them up to balance as one group?
4.) Are you better off charging all 4 packs through their main leads all connected together, or splitting the charger into the two DB8(s) directly?
5.) Would a Fire-Safe Bag per pack insulate the heat, effectively reducing the packs overall life?
6.) For the LVC would I need to send 4 sets of balance leads up the handlebars with 4 individual CellLog 8s displays? Or is there a better solution available?
Any input would be greatly appreciated, been researching hard for the past few days but can't seem to find the answers I seek. Unfortunately being a perfectionist at heart doesn't make matters any better hah! Cheers .
s
