E bike Lifepo4 ad on for a Gio Pb710+Lead
Ronthegood
10 µW
10 µW
Post by Ronthegood » Jun 13, 2017 1:08 am
Hi. Is it ok to plug in a Lifepo4(48v 20amp) into the charging port and not hurt the bike? Or hurt my lead batteries. I want to Plug it in and drive it with my lead batteries installed.
amberwolf
Re: E bike Lifepo4 ad on for a Gio Pb710+Lead
Post by amberwolf » Jun 13, 2017 1:47 am
As long as the new pack and the old one are at the same voltage when you connect it, sure.
But since the charging port is only capable of a fairly low current, normally, then if there is much of a difference, the current flow between the packs could damage the connector and/or wiring.
It's also possible it could damage the pack(s), depending on what their limitations are.
Ronthegood
10 µW
10 µW
Post by Ronthegood » Jun 13, 2017 4:16 am
Ty for your wisdom.I was hoping for less wiring work.Is it ok to run them in parallel?
Ronthegood
10 µW
10 µW
Post by Ronthegood » Jun 14, 2017 1:10 am
I found the answer here, endless-sphere.com/forums/viewtopic.php?f=14&t=7740
Ronthegood
10 µW
10 µW
Post by Ronthegood » Jul 19, 2017 11:19 pm
amberwolf wrote:As long as the new pack and the old one are at the same voltage when you connect it, sure.
I have a new ? for you, will paralleling my slb 12 amp with my Lifepo4 20 amp will it do bad things to slb with them having a 8 amp difference ?
marcexec
Post by marcexec » Aug 02, 2017 4:17 am
You're fine paralleling different capacities, just keep an eye on the voltages before you do (SoC should be close).
A motorcyclist is never late, Frodo Baggins. Nor is he early. He arrives precisely when he means to.
My Suzuki RF400 build: now with Enertrac MHM602 and 6kWh AESC modules protected by a Zephyr BMS
Renault Equation modded to 10S6P recycled laptop 18650s & 1kW controller.
Master of Electric Motor Selection: "Adopt a motor" (PM me if you have trouble editing)
All the gear, all the time!
