1970 Vespa 50s electrification project
mistercrash   10 kW
Re: 1970 Vespa 50s electrification project
Post by mistercrash » Aug 30 2017 10:09am
No need to remove the pin from the swing arm to remove the wheel.
I am so sorry that you are experiencing difficulty in your life, but if you send $10 at paypal.me/Ray1964
, you will be in my thoughts and prayers.
EddySPalm   10 W
Post by EddySPalm » Aug 30 2017 12:14pm
SlowCo wrote:If you want to slide the wheel into the swing arm dropouts surely the pin should be bolted to the swing arm afterwards and removable to be able to get the wheel assembly out later?
I think a little clever dimensioning can accommodate for inserting the motor at a slight angle, but I sure have to make sure :D
EddySPalm   10 W
Post by EddySPalm » Aug 31 2017 2:44am
Got to work a few hours on the scoot last night. Battery pack is so close to being completely welded, and the controller room is turning out great! The plywood is ready to be laquered and eventually get some holes drilled/have some threaded inserts inserted, for mounting of the controller :D Also took some more measurements of motor and brake assembly so I can continue modelling on the swingarm.
2017-08-30 22.39.29.jpg (210 KiB) Viewed 2444 times
2017-08-30 22.41.15.jpg (135.72 KiB) Viewed 2444 times
2017-08-30 22.41.21.jpg (126.74 KiB) Viewed 2444 times
EddySPalm   10 W
Post by EddySPalm » Aug 31 2017 8:59am
As I approach finalizing my battery pack I am going to need a charger! Can anyone please recommend me a 10-20A charger, preferably with adjustable voltage?
wineboyrider   100 MW
Post by wineboyrider » Sep 01 2017 10:50pm
Meanwell HLG series.
EddySPalm   10 W
Post by EddySPalm » Sep 04 2017 2:41am
LED driver, interesting!! I can't find any in the HLG series that supplies more than 50-something volts though, maybe I should look through another series?
wineboyrider   100 MW
Post by wineboyrider » Sep 04 2017 9:40am
http://www.meanwell.com/webapp/product/ ... d=hlg-600h
Use them in series for higher voltage.
wineboyrider   100 MW
Post by wineboyrider » Sep 04 2017 9:41am
I actually use 2 24v meanwells to charge 12s lipo at 10.8 amps .
marcexec   1 kW
Post by marcexec » Sep 06 2017 3:47am
I'm using 2x USP-500-48 (PFC).
Note that they need a current limiting circuit or will break.
A motorcyclist is never late, Frodo Baggins. Nor is he early. He arrives precisely when he means to.
My Suzuki RF400 build: now with Enertrac MHM602 and 6kWh AESC modules protected by a Zephyr BMS
Renault Equation modded to 10S6P recycled laptop 18650s & 1kW controller.
Master of Electric Motor Selection: "Adopt a motor" (PM me if you have trouble editing)
All the gear, all the time!
whereswally606   100 kW
Post by whereswally606 » Sep 07 2017 1:50am
I like the Minghe bst dcdc, they do up to 80v and 15A. Are current limited and have a digital screen for £15 you need a DC power supply then to supply it. There are even 20a,30a and 50a dcdc with current limiting which are fairly cheap but they don't have a display so you need a separate volt and ammeter to set them up via the trim pots. I like the idea that you can carry an emergency power supply (a light one) but have the beefy ones either end of your commute. Stash a few at friends houses. I'd other server power supplies.
Sent from my ALE-L02 using Tapatalk
Distributing "Lebowski" FOC Controller PCB (Through hole) since 2016
Moped: Emax 110s 2009
EddySPalm   10 W
Post by EddySPalm » Sep 07 2017 3:28am
wineboyrider wrote:Good tip
marcexec wrote:Good tip
whereswally606 wrote:Yet another good tip
Thank you, I'll look into this too. I was hoping to find something IP67/68 rated, as it will be mounted inside the left rear "bubble" of the chassis (I'm out of room underneath the seat).
marcexec   1 kW
Post by marcexec » Sep 07 2017 4:26am
EddySPalm wrote:I just paid my way out of any fiddly brake set-ups: Found a company who sells hydraulic conversion brake pedal especially made for my Vespa! Includes a cast aluminium brake pedal with brake switch and master cylinder. All I need now is to run my brake hose back to the disc brake.
Eddy, as I just went through this myself, you might want to consider triggering regen only from the rear brake. I solved this with a Schottky diode.
Let me know if you'd like a diagram.
EddySPalm   10 W
Post by EddySPalm » Sep 07 2017 5:17am
Hey, thanks markexec! I was acutally thinking of using the "activate regen upon throttle release" function to begin with. Do you have any pros and/or cons with regards to this? I can only image what the different options will be like, as I've yet to try any of them...
EddySPalm   10 W
Post by EddySPalm » Sep 07 2017 5:20am
My rear brake is hereby converted:
2017-09-04 22.14.19.jpg (231.1 KiB) Viewed 2293 times
2017-09-04 22.38.35.jpg (193.94 KiB) Viewed 2293 times
I finally have a tire for my motor:
And I officially have a 60V battery pack (welding all done):
Slow and steady wins the race 8)
marcexec   1 kW
Post by marcexec » Sep 08 2017 5:09am
Shiny equipment there mate. :D
My thinking is that I want to be able to control the rear brake independently from the front, thus the disconnect.
With the weight in the hub (potential) rear braking force will be stronger than before, so I want strong regen to help the smaller rear caliper. See my thread for some pics.
As mentioned, the cable throttle on the clutch lever might be used to adjust. The Kelly has a few options to play with.
I don't think I'd want much "engine braking" on throttle release, coasting is more efficient. I can always "kick it off" with a light press on the rear brake. Added benefit is that the brake lights light up on regen for safety.
Hope that makes sense :)
EddySPalm   10 W
Post by EddySPalm » Sep 12 2017 7:03am
marcexec wrote:Shiny equipment there mate. :D
Wait, are you saying the enormous rear brake that came with the motor might not be sufficient? It's like 10" in diameter :O
Yeah, I like the idea of using the cable lever as a "3rd" brake, that would be incredibly cool. I just bought a cable operated 0-5V hall effect sensor (for the throttle), maybe I should have gone for two...
I wish this all made a little more sense than it does at the moment, you're saying you want to control the rear brake independently of the front. Did you have one common pedal for front and rear? Sorry that I haven't pressed your links yet, maybe if I read through yopur posts I would have understood more.
wineboyrider   100 MW
Post by wineboyrider » Sep 12 2017 7:19am
Are you going to use regen?
EddySPalm   10 W
Post by EddySPalm » Sep 13 2017 1:15pm
wineboyrider wrote:Are you going to use regen?
Yes, in one way or another...
marcexec   1 kW
Post by marcexec » Sep 13 2017 4:14pm
EddySPalm wrote:[..]
No, I just want to have to have control, i.e. no regen on the rear wheel when I press the front brake.
Keep in mind that the regen is electrically activated from the 12V circuit, i.e. the brake light, thus the diode.
EddySPalm   10 W
Post by EddySPalm » Sep 14 2017 5:47am
marcexec wrote: Keep in mind that the regen is electrically activated from the 12V circuit, i.e. the brake light, thus the diode.
The wiring diagram for KEB72601 says different? It says to use 5V from the controllers' 5V output. I'm not branching in on my 12V (or actually 6V) system anywhere except that everything 12V will be powered from 60V-12V DC-DC converter.
For the record I will be converting the 6V system to 12V now that the scooter no longer has its old ignition system any longer.
marcexec   1 kW
Post by marcexec » Sep 14 2017 8:59am
Kellys work best fully isolated, so I'm using a relay to trigger the 5V from the 12V brake input.
EddySPalm   10 W
Post by EddySPalm » Sep 14 2017 1:05pm
marcexec wrote:Kellys work best fully isolated, so I'm using a relay to trigger the 5V from the 12V brake input.
Sounds like a very good solution for you! I was planning on using a separate switch, as I have so much room to fit it around the brake pedal :) Thanks for your input! I do appreciate it, it's just that sometimes my knowledge just doesn't cut it :lol:
EddySPalm   10 W
Post by EddySPalm » Sep 20 2017 2:39pm
- Cable actuated throttle came in, and looking good! With some soldering I should actually be able to use a standard Vespa throttle cable on this one.
- "Ignition" switch came in. Now sadly I have to find out where to drill a hole through my lovely untouched Vespa. I could make it work with a bolted bracket somewhere under the seat though, but would it be as slick?
- charger on its way. Opted for a Supower 8A (67.2) one.
- Found a good solution for mounting the cycle analyst. Pictures to come once its done.
2017-09-14 22.02.51.jpg (183.69 KiB) Viewed 2053 times
2017-09-13 19.32.25.jpg (142.32 KiB) Viewed 2053 times
marcexec   1 kW
Post by marcexec » Sep 20 2017 5:10pm
Glad that what I found works out for you!
One note on the connectors, I use the waterproof ones liberally (on the car as well). I think they are Tyco knockoffs. 15 sets are less than $7.
Flat pliers work, but long term you'd want a crimp tool, I have something similar to these.
Edit: in 1 and 2 pins as well, of course.
Instructions:
EddySPalm   10 W
Post by EddySPalm » Sep 21 2017 3:18pm
marcexec wrote:Glad that what I found works out for you!
Me too! And I completely forgot to thank you :roll:
It looks like a really solid piece of kit. the casing is cool; injection molded with no respect to wall thicknesses whatsoever, still not a single sink mark or warp. What material might this be?
Today I sourced the rest of the materials I need for the swingarm, and it's all free up until now. I will get one of the machnists at work to cut and machine the stock, with the exception of the part where the square section meets the tube, I gotta go to a friends' shop for that one. That same friend will tack it together for me while I'm there to double check the fit, and then finally I will take the tack welded assembly for final welding at yet another machine shop. That's how it's gotta be when the skills and machines you need to complete the job is not all together :lol:
