x.l.r.8
So the scenario is, I got my hands on a beat up EM1 sans battery/charger. I have a few packs I can use, a 48v 36Ah Pack and a 52v 30Ah pack. The controller is programmable so I know that will be fine for either pack. The last part of the equation is the motor. I think I know the answer but all the writings here talk of running 72 volts through a 48v system. I think if my reading is correct feeding the 72v hub will only result in a decreased speed and torque, that being said many hub motors are advertised as 48-96v only the rpms drop with lower voltage. So my questions are 2 fold. Will the motor work with less voltage, I'm not looking to rock the world , 32 - 45km/hr will be okay for the moment? Will say a 48v motor rated around 1500 watt be any improvement. The controller Max's out at 50Amp so I don't see many issues other that the motor is incompatible with my plans so I'm looking for honest opinions, again the plan is a reliable speed with good torque. Is the motor useless for this plan, I have no issues selling the motor on and buying something that will work if this won't.
