Add rear hub motor to front wheel?
ford442   100 mW
Post by ford442 » Nov 21 2017 5:55pm
I have a 60V 1000W Citycoco scooter and I am thinking of attaching a rear tire with motor to the front fork. Not necessarily to run though. I want to attempt to generate power only first. The issue is that the motor appears to be physically built to bolt down to the squared off metal of the frame the accept larger bolts than the front wheel on a Citycoco.
I have not yet tried removing the front wheel and placing the second wheel in place.
Does someone know offhand? I see that there was a kickstarter/indiegogo version of the same scooter that had a front motor. Is it easy to modify the part that connects a Goldenmotor style hub motor to exterior frames? What type of business should I contact to have it done?
SlowCo   10 kW
Re: Add rear hub motor to front wheel?
Post by SlowCo » Nov 21 2017 7:20pm
Why not use the rear motor to do regenerative braking?
Or where you thinking of using a front motor to generate energy while riding? Because that would cost more energy than it would generate...
amberwolf   100 GW
Post by amberwolf » Nov 22 2017 12:43am
regarding the mechanical installation, unless the rear wheel is the same dropout width as the front fork, you'll have to have someone cut your fork up and rebuild it into a wider one, or replace it with a fork that is wide enough to hold your rear wheel, if one even exists that can do so.
then you will need to ensure there are torque arms or clamps on teh dropouts to hold the motor axle securely. without them there can be a risk of the wheel ripping out of the fork, which could land you on your face sliding down the road.
he has a thread for the generator stuff
https://endless-sphere.com/forums/viewt ... 8#p1317118
i'm guessing this thread si only for hte mechanical of putting a rear in the front. If not the threads should get merged to keep the whole project in one thread so he gets all the right answers from those already helping him.
John in CR   100 GW
Post by John in CR » Nov 22 2017 10:45pm
For s similar installation, I made L shaped clamping dropouts cut from 3/8ths stock. The horizontal part clamped to the motor axle. I welded the longish vertical part of the L's to 2 pieces of tubing that were sliced open lengthwise. The tubing slid over the lower end of a motorcycle fork, and I fashioned clamps squeeze the fork as secondary security for the silicone that I slathered the inside of the tubes with to act as glue and prevent galvanic reaction between the steel and the aluminum fork lower.
Here's what they looked like in raw form
Moto fork dropout sleeve.JPG (19.58 KiB) Viewed 1102 times
ford442   100 mW
Post by ford442 » Nov 23 2017 4:38am
John - what about the difficulty of making a little fork that merely ties to the wheel?
Making it like a one-wheel trailer simply to drag behind.
Can you think of an easy source for such a part?
amberwolf   100 GW
Post by amberwolf » Nov 23 2017 6:43am
BOB trailer
but you'd still have to add torque arms, etc. just like with a front fork.
and if you're using a rear wheel on it you'd also still have to spread it's dropouts apart, or cut and modify, etc.
John in CR   100 GW
Post by John in CR » Nov 24 2017 10:00am
Unless you plan to power it for 2wd, there is no meaningful upside to going to the trouble of adding a front motor. Generating net power to store or use certainly isn't possible.
ford442   100 mW
Post by ford442 » Mar 14 2018 2:51am
Any idea how much it would generate though?
ford442   100 mW
Post by ford442 » Mar 14 2018 2:52am
SlowCo wrote:
Nov 21 2017 7:20pm
How would I go about adding it to my already build scooter? It is a matter of the controller's features?
SlowCo   10 kW
Post by SlowCo » Mar 14 2018 7:26am
You need a programmable controller for that (regen. braking).
The only real benefit is less wear on your brake pads and a slightly longer range.
ford442   100 mW
Post by ford442 » Mar 14 2018 8:17pm
OK. I think I see. There are just a lot of price ranges of them I guess. Looks like maybe $250 can do it..
