MDW195 said:
The throttle has no LED indicators working
what specifically are the "led indicators" for? what do they indicate when they are working?
what specifically happened between the time they *were* working, and the time they stopped working?
As I have another issue with the bike, and that is it will completely cut off during a ride
if all power completely shuts off, then that is a power issue, and is usually a battery's bms shutting the output off to protect the pack from overdischarge that does this.
if the pack dosen't have a bms, then that's not it.
but it could be literally anything between the cells of the battery, and the controller, cutting off power.
put a multimeter set to dc volts with it's leads directly on the battery outputs, then ride, and note what you see on the display. if the display never drops significantly, then it's not the battery itself, or it's bms (if any). if it drops way way down when the problem happens, the problem is between where the meter leads are connected and the cells of teh battery.
if it isn't there, then move the meter leads further downstream, to where the battery connects to the next thing, whatever taht is. if the problem shows on the display there, then ti's between that point and hte previously tested point.
and so on.
