Satellite scooter not working
TerraceScooter   1 µW
Post by TerraceScooter » Feb 19 2018 11:00pm
Hello, thanks for reading this. I'll make it quick: I have 2 identical scooters, I got them used and both not working. Here is a link to a video that says a lot: https://youtu.be/f8_h6fijSGg
It shows that everything is working except one relay doesn't engage when the throttle is pushed, but when I engaged it manually the motor spins until the throttle is released. I've tried this on both scooters with the same results. Any ideas? Thanks again!
amberwolf   100 GW
Re: Satellite scooter not working
Post by amberwolf » Feb 19 2018 11:59pm
Probably the other relay is supposed to be engaged by disengaging the brake, so most likely either there is a wiring problem (bad connection, broken wire, etc) or a bad brake switch causing no connection to engage that relay, or the relay itself is failed.
That's what is wrong with the little kickscooter i have here:
https://endless-sphere.com/forums/viewt ... 1#p1305286
the relay coil is actually burned out so it can't be engaged electrically anymore.
TerraceScooter   1 µW
Post by TerraceScooter » Feb 20 2018 9:45pm
Hey amberwolf: thanks for the reply. It's amazing looking at your story and seeing how similar your problem is to mine. Although I must say you have a more complex machine, and you post a better story - I need to step it up! I'll update any success I have. I'm having fun just trouble-shooting the scooter, and it's nice to see such an active forum. Thanks again!
amberwolf   100 GW
Post by amberwolf » Feb 21 2018 12:49am
I'm not sure how much simpler one of these could be than the thing I have. :lol:
Post pics of yours so we can see what it is, inside and out--someone else might already have the same thing with the same problem and know exactly how to help you fix it. :)
