Magura 5K twistgrip throtthle and Kelly Kls 200
Speedproject   1 µW
Post by Speedproject » Jun 22 2018 12:25am
Hi,
i bought the mighty magura throttle, but can't get it to work smooth.
My controller don't start if i activate the 0-5 k mode when i set it to 3 in the tps square. When its set to 1 or 2 = 1-5v , 1-4v the motor starts, but very hard. Its not very smooth like i wouldhave it to be, how can i get it to work right. Thanks :) :wink:
BULLS Copperhead: Mxus3000 3t 17in , kelly kls 7218s 200A (65a battery set) Magura throttle + 12x Multistar 6s 5200 (12s) :mrgreen:
eee291   10 kW
Re: Magura 5K twistgrip throtthle and Kelly Kls 200
Post by eee291 » Jun 22 2018 12:45pm
Could it be that you didn't do the auto identify procedure?
I had the exact same issue.
flat tire   100 kW
Post by flat tire » Jun 22 2018 1:19pm
The Magura is a terribly overrated and underperforming throttle, best to get a Domino.
Speedproject   1 µW
Re: Magura 5K twistgrip throttle and Kelly Kls 200
Post by Speedproject » Jun 22 2018 3:58pm
I now soldered a 10 k poti i took from a subwoofer modul that should move to the recycling station between the plus wire but now i got the axle bent because the motor stops abrupt if i close and open up the throttle a little... does anybody now which setting in have to change, i had free today and tried the half day to get things right :?
maitilupas   100 W
Post by maitilupas » Oct 02 2018 1:24pm
did you solve the issue?
KLS have deceleration settings
skeetab5780   10 MW
Post by skeetab5780 » Oct 02 2018 4:42pm
Did you put the resistors in place properly? Im not sure if you need to do this with the kelly controllers but you had to to make them work with lyen/infineon clone controllers. This old vid of mine shows how to do it.
If you do this you may be able to leave the kelly settings alone as they are stock
