E-Max 90S questions.
jonescg   1 GW
1 GW
Re: E-Max 90S questions.
Post by jonescg » Aug 24 2018 3:45am
offpist1 wrote:
Aug 24 2018 12:36am
Maybe you did not read the whole tread, but i have 21S of 50AH Lithium-Ion (3,9KWH nominel), not SLA.
My apologies - was hard to see the whole context on the phone.
21s - must go pretty quickly!
offpist1   10 mW
Post by offpist1 » Aug 24 2018 7:38am
Yes, its quick ;)
Pushing 90+ km/h and it gets there very fast.
Quite happy about it.
I also ordered an new rear damper for it, should arrive sometime next week.
jonescg   1 GW
1 GW
Post by jonescg » Aug 26 2018 6:32am
Any improvement to the suspension is going to be noticeable right away.
offpist1   10 mW
Post by offpist1 » Sep 06 2018 10:24am
The rear suspension is now perfect..
This winter i will take apart the front suspention and try to find some softer springs to fit.. the front is way to stiff.
olalid   1 µW
Post by olalid » Oct 04 2018 11:30am
Interesting thread, I have an E-Max 90S with a broken motor controller, since it is the same type of epoxy covered design as in the pictures in this thread it is very hard to examine it and try to understand what can be wrong with it.
I have had very little luck in finding any information about the original motor controller on the internet, but the schematic in this thread is very interesting information and should make it easier to replace it with something else.
Did you find out everything you posted in this thread by reverse engineering, or did you find some documentation somewhere?
offpist1   10 mW
Post by offpist1 » Oct 04 2018 11:23pm
[Moderation: forsale offer in tech forum deleted]
The schematics for it is attached.
Controller user manua- proud-eagle.doc
(463.5 KiB) Downloaded 28 times
olalid   1 µW
Post by olalid » Oct 08 2018 11:00am
The manual you attached offpist1 mentions an LED code reference table, but it is not included in the document.
My controller does flash some pattern on the LED, so would kind of be interesting to find out what it means, in case the problem is actually external to the controller...
So if anyone knows about those codes, please let me know.
Otherwise, well, for the right price I can perhaps be interested in the original controller, do you have any idea what you want for it?
I was originally thinking I wanted something more robust and potentially better performance, since it seems from what I read that these controllers break quite easily.
But of course just replacing it with an equivalent is a lot easier...
I am not interested in another complete scooter, actually I was not planning on keeping mine either in the long run. :)
whereswally606   100 kW
Post by whereswally606 » Oct 09 2018 10:53am
from the file in the software manual filename begins E2 - ...
controller led blink codes.png (53.82 KiB) Viewed 337 times
hope this helps
Distributing "Lebowski" FOC Controller PCB (Through hole) since 2016
Moped: Emax 110s 2009
olalid   1 µW
Post by olalid » Oct 11 2018 3:41pm
Great, thanks.
Interesting, mine is blinking 6 times.
Which either is "Scooter disabled", whatever that means (it does say "Vehicle disabled" in the instrument cluster display), or side stand out.
As I remember it when the side stand is out, it displays a message more specifically about that in the display, does it not?
Post by whereswally606 » Oct 12 2018 10:19am
yeah I think you get side stand out message on the display.
