TilmanBaumann
- Joined
- Feb 15, 2018
- Messages
- 120
I'm looking at replacing the motor in my scooter. Right now it uses a 48V 8.5kW Lynch LEM-200 motor overclocked to 72V. (yes that is factory default. And yes, it overheats)
I'm looking for a brushless motor that achieves around 15kW at 72V with a diameter of not much more than 205mm.
So far so easy, many options come to mind.
But here is where I'm stuck. How to I calculate the correct KV range and desired max RPM?
I guess naively, I could calculate back from expected cruise speed (let's say 120km/h) tyre diameter and belt teeth ratio.
Does this approach make sense? How can I tell if I overdid it? I will sacrifice top speed for acceleration, I just don't want to hit a brick wall at speed with power to spare.
What is a sensible approach to select the right motor?
My goal is great acceleration and fun. Sensible efficiency at normal use.
Allowed power for the class of vehicle is 11kW. But I'm not concerned about bending the rules here a bit. I'm even considering re-classifying the scooter as a motorbike.
Speed is not the prime focus. But above 110km/h is must to flow in traffic.
I suppose I will need the gearing ratio and tyre dimensions. I will find those out next...
