yellowscooter
100 µW
- Joined
- Aug 25, 2018
- Messages
- 8
Hoping someone here may be able to help. I have an EVT 4000 E scooter, 2003, brushed motor. Scooter has been solar charged since 2005 with 120 watts of on board solar panels. It was siting outside for a couple of years, needing a new set of batteries. Installed those a couple of days ago. Have an intermittent electrical problem. Scooter will turn on properly, all lights correct, will run when throttle twisted until braking. Then stops and will not run unless sitting overnight.
I may have kind of figured out problem. Pondering solution, hoping someone may know.
I think the problem is related to the brake levers when they disengage the throttle electronically when applied. If I ride and do NOT use the brakes there is no problem running (went a couple of miles starting and stopping without using brakes and no problem. If I apply the breaks, the motor will not go forward using the throttle. Interestingly, the rear/brake light disables when this happens. Everything else stays on, except the rear/brake light. I have to wait over night for it to run again, or....take the rear/brake bulb out of the socket, turn on and then off the bike, then on again and the motor will run.
I am going to take out the brake levers and clean them to see if an internal fault from sitting outside for many Michigan winters may have moisture or corrosion inside the switches.
Is anyone aware if I can disable the brake lever switches without the rear light going out? Since the actual brakes are hydraulic, they won't change if the switch is disabled.
