Darren xmr
- Joined
- Jul 8, 2018
- Messages
- 2
I have a motorino xmr and my batteries were getting weak...also my charger would make a whining noise intermittently when I first plugged it in, I purchased brand new batteries and installed them...my volt gauge on my bike showed 77.5 volts when I first turned the key which is low and no surprise as I was told they would need a charge...I plugged the bike into the charger and had a shower I checked on it about 45 minutes later and the charger had shut off all ready...I turned the key on and it showed 80.5 volts...so I went to try it and the bike behaved like the batteries were dead so I plugged it in again and the charger only ran for about 5 minutes and shut off and again the volts showed 80 so just played with the lights etc. And sure enuff the volts started dropping. Does this sound like a bad chargeer or a problem with the bike...thanks in advance for your opinion
