Common high current connectors - and my opinion on them
A place to list links to sources for EV related parts and services.
Matt Gruber   100 kW
Re: Common high current connectors - and my opinion on them
Post by Matt Gruber » May 01 2014 7:57am
is anyone else making their own? instead of that bulky and expensive plastic housing, i'm trying double heat shrink over male/female generic connectors. i have substituted a fuse for one connector in each string. this way the string comes apart easy and is fused. For charging i use one male spade, and one female on opposite sides of the bike so they can't ever touch, even in a crash. can't hook it backwards and it is double heat shrinked. costs close to nothing to make.
has anyone checked the voltage drop at rated amps? i'd expect old fashioned twisted copper with a wire nut to be superior. i'm using this old school method where ever i don't need a fast disconnect, but don't want to solder. There should not be ANY voltage drop because the twisted wire doubles the copper at the twist.
ASE CERTIFIED IN ELECTRICAL SYSTEMS 1984- retired
Converted window AC's to central system.
Testing various foods.
Finished testing JB Weld cell fuses. No more soldering to a bare cell for a repair.
Why build a pack from scratch? I buy tool packs instead.
simpes   10 µW
10 µW
Post by simpes » May 23 2015 10:00am
There are hobbyking XT90 anti-spark connectors. They use a 5.6 ohm pre-charge resistor. There is another thread discussing about it here:
http://endless-sphere.com/forums/viewto ... 35&t=63210
Quinc   10 W
Post by Quinc » Nov 26 2018 7:11pm
Picked up these 0/1ga welding connectors. Much cheaper then Anderson of similar amp ratings.
I'll post back at some point with how well they work out.
https://endless-sphere.com/forums/viewt ... 4#p1426594
nuxland   100 W
Post by nuxland » Nov 27 2018 1:57pm
Can you weight one pair with plastics?
Want to know how heavy it will be if I will use 3 pairs.
Quinc   10 W
Post by Quinc » Nov 28 2018 4:08pm
nuxland wrote:
Nov 27 2018 1:57pm
Not much. Somewhere between 1 soft taco and 3 crunchy tacos in weight. :mrgreen:
ichiban   10 W
Post by ichiban » Dec 02 2018 12:07pm
Just came across this :
OSE 8.0mm ANTI-SPARK CONNECTORS 200 AMP PLUS
https://www.youtube.com/watch?v=zwYjXTx ... e=youtu.be
I have not verified anything yet regarding the accuracy of the info from above clip. But it sounds crazy @ 200Amp + already.
eee291   10 kW
Post by eee291 » Dec 02 2018 12:32pm
The seller I bought them from claims 150A
https://www.ebay.at/itm/5-Paar-Hochstro ... 2630959876
ichiban   10 W
Post by ichiban » Dec 02 2018 9:33pm
Still a big WoW @ 150A !!
Considering a small plastic connectors that size.
So we can jump start a car with the palm size Lipo @ these tiny connectors.
