Common high current connectors - and my opinion on them
Re: Common high current connectors - and my opinion on them
Here's a few other places that sell Anderson Power Pole connectors:
http://www.dcpwr.com/products/productli ... 4f97762c27
http://www.powerwerx.com/
http://www.cablexperts.com/cfdocs/cat.c ... ship=1&c=0
- snowranger 10 kW
What makes the mail order andersons expensive is the shipping. Here's a place that has good prices and low shipping. I just bought my last set from here.
http://www.alt-moto.com/
Electric: BBS02 / Nuvinci Developer Kit / 14s Li
Bike : Yuba Mundo
Accessories: 12 volt lighting, 48V horn
Miles: 300 mi
Bike : Yuba Mundo
Miles: 300 mi
Thanks for the resources. Is there any trick in assembling the Andersons? I just got a baggie full of them from ebikes.ca with no instructions.fechter wrote:Here's a few other places that sell Anderson Power Pole connectors:
I'm thinking you just crimp/solder them then stick them in...the crimp tabs seem polarized (blade is cupped). Any trick to sticking them in right?
with bigger gauge wire they just snap in.. but with thinner stuff you can use a small jewlers screwdriver or something similar to push the trip into the housings.. i made a picture thread of this a while ago... will try to dig it up
Pictures and tips for assembling Anderson Powerpole connectors:
http://www.westmountainradio.com/supportrr.htm
Thanks Ypedal and zootkatz!... link in particular is very helpful. Looks like it'll only "snap in" one way...this is good!Zoot Katz wrote:Pictures and tips for assembling Anderson Powerpole connectors:
****COUGH!!!!!!! COUGH!!!!!!!!!****
I know this is a dusty old thread, but I have a couple of Q's
First off, connectors:
One thing I didn't see addressed, is weather (particularly rain) resistance. I don't like to ride in the rain, but I live where rain is almost always a possibility, most any time of the year. I found some plugs at the local hardware store sold for use with power sprayers (pesticides) so I don't know what to call these or what they could be rated to handle (14G wire), but, the plugs that are 2 wire yet similar to the 4 wire trailer in that it is rubber, polarized, and I think, weather resistant.
Are any of the connectors listed on this post designed with weather (particularly water) resistance in mind?
Also, I am very curious about the parallel resister pre-charging circuit. Is this circuit still necessary with an adequate switch between the battery and the connector?
I understand that the switch takes the brunt in this situation, so maybe a relay is more practical?
I have only been using an Amped Bikes DD rear hub kit in it's nominal 36v power, and my next kit I plan to run 56v, so I am looking into what I will need to up-grade.
Another question (hope it's not too far OT hehe) is, if I up the voltage, yet stay low in AH's, will that be easier on the system? I'm sure a lot of these Q's can be answered with a better understanding of basic electrical theory, but I am afraid many of you have forgotten more than I have ever known, so until I am able to take some courses, I'm relying on your exceptional knowledge and patience.
Thank you Justin_Le for your selfless act of kindness! We all are in your debt.
Back on track E-Bronco! Now with Cro Motor Mid-Drive Goodness!
https://endless-sphere.com/forums/viewt ... 28&t=44997
Vision R40 w/3000w MXUS as mid-drive, NuVinci N171B rear wheel as transmission, Silent yet powerful, running 72v 11.6 ah (20s 18650 Li-Ion) to climb hills, tow trailer with zero pedaling when needed!
https://endless-sphere.com/forums/viewt ... 28&t=75247[/size]
I have seen Molex and bullet crimp connectors on a 36V 15A controller feeding a 250W motor that had melted and fused together.
This thread also shows the down side of using 'bullet' connectors, but I think they are actually banana connectors.(you need to scroll dwn the page a bit to see the photo)
http://endless-sphere.com/forums/viewto ... 2&start=75
Re: Metallover's 9c Blackcomb Build
by Metallover » Sat Mar 27, 2010 12:30 pm
... I am about done with my Bullet Plugs. The last short I had to open up one of my zippies and re-solder one of the tabs. It was blown apart. This new short today is the one that sent me over the edge.
E-bikes: Bafang 8FUN; Mac; Ezee; FreeGo; Aprilia 7s LiPo; eLation V2; TerraTrike recumbent
E-motorbikes: ZEV 7100 LR scooter, 84V 60Ah LiFePO4.
ZERO 2011 S motorcycle, 51.8V 70Ah LiMno2, 2012 headlight, Kilovac EV-200 contactor
E-mower: EGO 56V mower & line trimmer
I have a pair of Power Poles with a 1K resistor in line that I connect first, then a second pair that I connect a few seconds later...
It mostly eliminates the massive POP when I connect the battery, and keeps the contacts clean.
Im only using the standard little 45A? PP's, but they dont have a issue at all with 60A running through them. The wire is warmer than the contacts.
I have been using these bullets on all my connections both motor/controller and phase wires. They can take quite a bit of current, as 10 GA wire gets hotter than they do. And for the price you can have either 1 set of Andersons, or 10 pairs of these. plus they come with really good heat shrink
http://www.dealextreme.com/details.dx/sku.41134
Test Review Revise Repeat
Any comments on the XT60 connectors? I got a bunch because it seemed like a good idea at the time.
New to endless-sphere? Notice a lot of signatures recommending Ebikes.ca? That's because it's the best place for a quality and manageable, (but still 'real'), first build. Justin is a solid supporter of electric bike development, and a good source of equipment.
I love em. I haven't pushed the amperage limit on them, but they take many many connect/disconnect cycles and don't wear. They are very durable, and fairly easy to solder. In my opinion, they are leagues better than problem prone andersons.
9c 9x7f w/ 12awg phases
9c 8x8r w/ 10awg phases, temp sensor, vented
9c 6x10r w/ 10awg phases, temp sensor, liquid cooled, 3rd Place Pikes Peak 2012!
"Don't argue with the galactically stupid...they drag you down to their level and beat you with experience"
- nonlineartom 1 kW
What are people commonly using for X5 motors being pushed hard? My X5 is still running standard PP45's but I'm feeding it more than 45 amps, do you go to 6mm bullets?
Commuter bike: 10T MAC Schwinn Panther Beach Cruiser on 12S LiPo, super stealth hill eater
Forest trail eater: Crystalyte 5306 KMX Viper with 24" wheel. 100A controller 18S LiPo
Pocket rocket: 8T MAC e-BMX 18s LiPo. Missile for testing to destruction
Summer ride: 8T MAC Kona Joe MTB / chopper / beach cruiser hybrid bike. 24" wheels and a lot lot of style.
Respect and fear the ancient god LiPo and pray he is merciful.
the HK 4mm bullets like these run great on a 130A 100v setup:
http://www.hobbyking.com/hobbyking/stor ... _set_.html
I am now using XT150 all over
they rule! and come with great housing - in different colours. Perfect for phase wires.
They can take a lot of amps, more than 4mm connectors by far.
Velokraft Batmobile
KMX Cobra with Xlyte 5403
Go-One Evo with Cromotor
BATMOBILE - in progress
Giant CRS Alliance - SOLD
3Element Espire - SOLD
Custom built Specialized BigHit with BBS02
Velokraft e-VK3
Velokraft Vk2
Steintrike Mungo Sport HS3540
Scorpion FS HS3540
Kona Dawg BMC v2
Velokraft e-VK3
Velokraft Vk2
Scorpion FS HS3540
Kona Dawg BMC v2
I have them too. They are smaller than XT150. But it is good to get them with the plastic housing [available in red only] instead of heat shrinks...Farfle wrote:I have been using these bullets on all my connections both motor/controller and phase wires. They can take quite a bit of current, as 10 GA wire gets hotter than they do. And for the price you can have either 1 set of Andersons, or 10 pairs of these. plus they come with really good heat shrink![]()
If anyone needs 4mm / 5.5 / XT150 / 6mm - i have plenty of spares to get rid of.
Velokraft Batmobile
Velokraft e-VK3
Velokraft Vk2
Scorpion FS HS3540
Kona Dawg BMC v2
Velokraft e-VK3
Velokraft Vk2
Scorpion FS HS3540
Kona Dawg BMC v2
Awesome post. I guess i may have gone overboard with using 75a andersons on pretty much everything. phases...(motor/controller) and all on my battery packs. lipo pack(4mm bullets) to a parallel harness that has 75a andersons. I will say this....when you have 5 rows of 75a andersons...don't even THINK ABOUT SLIDING THEM TOGETHER. if you do, you're never gonna get them apart again. As in, the andersons have those slots for connecting to each other. even two rows of andersons (4x4 pattern) are borderline impossible to take apart. I have cut myself multiple times..Looking to change my setup now. maybe 6mm bullets? dunno..
Current Build: Vector, MXUS 4T in 19" moto, Max-E, 20s8p Samsung 25R http://endless-sphere.com/forums/viewto ... =6&t=67752
Torque Raptor, Cromo V3 in 19" prowheel, Kelly KBL96251, 24s4p (SOLD) http://endless-sphere.com/forums/viewto ... =9&t=56342
Giant DH Comp, X5404/Cromo V2 in 26" rim, Kelly KBL96251/Lyen 18fet, 24s4p (SOLD) http://endless-sphere.com/forums/viewto ... =6&t=40031
- amberwolf 100 GW
- Location: Phoenix, AZ, USA, Earth, Sol, Local Bubble, Orion Arm, Milky Way, Local Group
- Contact:
Actually they can be easy to take apart. Set the row that slides back toward the wire face down on the edge of a table or something, with the row that slides forward away from the wire overhanging the edge. Press down on the back of that row with the edge of a hardcover book or block of wood or something similar that gives you a good handgrip to press against, then push down to slide them off.
You may have to use a second book or block against the opposing edge of the ones supported on the table, to hold them in place during the sliding of the others.
If you found this advice helpful, supporting contributions are accepted here.
"if it ain't broke, improve it till it is"----Dog-Hauler Cargo eTrike SB Cruiser----The HI-Lebowski: a Lebowski SMD brain running a zombified Honda IMA Inverter: a HOW-TO guide----Cargo eBike CrazyBike2----General Blog
- cal3thousand 1.21 GW
It takes practice, but I haven't found a single set of Andersons that I wasn't able to separate after "sliding" together. You have to make sure you are going in the right direction first!
Then, it takes even pressure from the top of one and the bottom of another to slide them apart. Having some slack before the wires enter a bundle also helps.
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
Here's a trick with andersons. Granted, they may get a lil loose if you do this too many times. You can just grab them from the sides with two pairs of pliers and flex them apart. they go snap! And then pop apart. This also works on the fused pair andersons, and I have not had a pair fail to slide back together afterwards.
Highly advise using a recharge resistor on systems over 36v.
A few years ago I made the switch to 30a Andersons as my default power connector and invested in the $45 crimping tool. Its so fast and easy. They are cheaper than the 50 and 175a models on a per amp basis. So I may just use 2 or 3 pairs to get the current rating I need for my bigger power systems. I bought a 175a one and its heavy - maybe a pound (pair). I get everything on eBay. $10 shipped for 10pairs of the 30a model.
Mush! Mush you electrons! Push harder!
Channel lock pliers work wonders for this. I find most pairs are very hard to slide apart by hand.cal3thousand wrote:It takes practice, but I haven't found a single set of Andersons that I wasn't able to separate after "sliding" together. You have to make sure you are going in the right direction first!![]()
i spent an hour and made 10 solid copper prongs for testing some of my makita packs.
but for the final install, i decided to hard wire direct because i live at the beach w/salt air and high humidity. everything will corrode over time.
can still test each pack with my copper prongs, just plug in and hook to load. this should meet my goal of "easy to service"
Few mentions of AWG size pertaining to all the connector selection. I'd sure like to see that. I just got some XT60 connectors, they SEEM fine, but the male side takes 10 AWG, the female 12. That just ain't right.
