Custom Torque Arms designed and fabricated
A place to list links to sources for EV related parts and services.
teslanv   100 MW
Post by teslanv » Oct 22 2016 5:38pm
After designing a few different torque arms for various bike frames, I have a pretty good grasp on technique and attachment method.
Generally, I like to use 1/4" thick 316 Stainless Steel, as it seems to be strong enough for most applications, and is readily available from my various sources.
To date, I have designed Custom Torque arms for the following Bike Frames, and all are available for sale:
You can purchase any of the above by sending me a PM. Prices range from $50 to $100, shipped.
For bikes not listed above, I will do my best to design and fabricate a set of custom torque arms for your frame. What I will need is a couple good photos, which I can import into my CAD software, and scale accurately. The best way to do this is to take a high resolution photo, straight on shot of each side of your bike's drop-outs, with a metric scale/ruler near the drop-out slots. (See Example Photos below). The metric ruler helps me to size the photo accurately in CAD. I then will engineer a profile for you to review. It will first be mailed to you as a PDF file for you to print, and model up within your frame. If all looks good, I will add your torque arms to my next batch of parts. This process will generally take 4-6 weeks. Cost for new designs will run about $300 for the first set, and $125 for additional sets of the same design, including shipping.
Send me a PM for more info.
TA Example 1.jpg (118.43 KiB) Viewed 2004 times
TA Example 2.jpg (182.58 KiB) Viewed 2004 times
CAD 1.JPG (54.97 KiB) Viewed 2004 times
CAD 2.JPG (59.9 KiB) Viewed 886 times
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
spinningmagnets   100 GW
Re: Custom Torque Arms designed and fabricated
Post by spinningmagnets » Oct 22 2016 7:06pm
This is awesome, and way overdue. Thanks for providing this service, Barent.
teslanv   100 MW
Post by teslanv » Dec 10 2016 3:18pm
Here is the latest custom project.
It's a Redline Monocog Flight 29er, that the owner calls "Kermit".
http://redlinebicycles.com/bikes/2014-monocog-flight/
These are 3D Printed prototypes used to test fit for proper geometery. This set is good to go. Next step is to order the waterjet cut Stainless parts.
This bike will be getting a 6T (6Kv) MXUS 3K-Turbo motor.
Bellevue, WA
USA
Suggs   100 W
Post by Suggs » Dec 11 2016 4:38pm
Great work Barent. In the middle of designing and making my own custom torque arms and it's not easy.
I'm sure you've already tried but can the axle nuts fit on? Looks a bit tight for space on the photos but the angle isn't quite right to be able to tell.
teslanv   100 MW
Post by teslanv » Jul 02 2017 11:09am
Add another frame to the list:
Motobecane 529HT from here: http://www.bikesdirect.com/products/mot ... nbikes.htm
Plastic Prototypes fit nicely. Fits M16 Axles and smaller. Just wait till you see the motor that this bike will be getting. :)
529HT Prototype Small.jpg (147.61 KiB) Viewed 1201 times
Motobecane 529HT - Small.jpg (117.86 KiB) Viewed 1201 times
Bellevue, WA
USA
tomjasz   1.21 GW
1.21 GW
Post by tomjasz » Jul 02 2017 11:25pm
Electra Townie. Pretty please.
Or another generic design with more posdible uses like Dr Bass!
My Gravity DeadEye Monster set are fantastic.
