Light Electro Bober (short version)
Alexander1971   10 W
Re: Light Electro Bober (short version)
Post by Alexander1971 » Mar 30 2019 1:41pm
Connected wiring,Bought a smartphone (Digma Linx A400 3G -$ 15) for the speedometer(smart bms)
https://youtu.be/H6DcQMO03LU
Alexander1971   10 W
Post by Alexander1971 » Apr 02 2019 6:06am
Kickstand
Dui, ni shuo de dui   100 W
Post by Dui, ni shuo de dui » Apr 02 2019 11:22pm
Wow, that's an amazing build, kudos!
We need more pics and more descriptions, don't be shy!
I'd like to build this kind of flat sheet frames one day, but I always wondered: how do you attach the main tube for the front fork ? (sorry, I'm not sure how it is called in english, I mean the tube with the bearings which connect the frame to the steering column?)
I believe that's the critical part to get right, would you mind explaining how you did it?
:bolt: :bolt: My electric Ninja 250 clone: 16 000W 72V40Ah A123 cells : :bolt: :bolt:
https://endless-sphere.com/forums/viewt ... 12&t=90032
:bolt: :bolt: My electric Scooter: 11 000W 72V 50Ah LiFePO4 cells: :bolt: :bolt:
https://endless-sphere.com/forums/viewt ... 12&t=75912
Alexander1971   10 W
Post by Alexander1971 » Apr 03 2019 8:13am
Dui, ni shuo de dui wrote:
Apr 02 2019 11:22pm
Hi!Thanks.
So
parts are made on a milling machine
Alexander1971   10 W
Post by Alexander1971 » Apr 03 2019 8:17am
cut and fitted a leather seat
Alexander1971   10 W
Post by Alexander1971 » Apr 03 2019 11:18am
saddle
Post by Dui, ni shuo de dui » Apr 03 2019 8:42pm
Alexander1971 wrote:
Apr 03 2019 8:13am
That's a clever solution, it doesn't seem to require any welding.
Great work, can't wait to see it finished!
Alexander1971   10 W
Post by Alexander1971 » Apr 04 2019 10:42am
Seat ready.......)
Alexander1971   10 W
Post by Alexander1971 » Apr 09 2019 4:53am
First charging,current 58Amp!
Alexander1971   10 W
Post by Alexander1971 » Apr 11 2019 10:35am
Motor burned out! Rotor rubbed against stator walls and overheated windings
John in CR   100 GW
Post by John in CR » Apr 11 2019 5:58pm
Sorry to read about the motor. What do you think the weakness was...poorly centered bearing cup, inadequate bearing support, a loose wire in the winding?
Am I looking at the pictures correctly and the headtube piece is only bolted to the frame, or is it welded? I'm always terrified of a failure in that area and opt for overkill in my welded connections.
Alexander1971   10 W
Post by Alexander1971 » Apr 12 2019 12:36am
John in CR wrote:
Apr 11 2019 5:58pm
Thanks.
It was displaced rotor axis (cover from another motor).
In the motor housing I made 3 inserts 10mm + the axis of the pendulum 12mm passes through the motor housing in (the motor housing had 4 through holes 10mm).
Alexander1971   10 W
Post by Alexander1971 » Apr 12 2019 11:58am
Bought a wire to rewind the motor!
Alexander1971   10 W
Post by Alexander1971 » Apr 12 2019 1:33pm
My sad foal!(
Alexander1971   10 W
Post by Alexander1971 » Apr 13 2019 10:42am
Wound phase...
Alexander1971   10 W
Post by Alexander1971 » Apr 13 2019 12:00pm
one more
Alexander1971   10 W
Post by Alexander1971 » Apr 13 2019 1:35pm
ready 3 phases
John in CR   100 GW
Post by John in CR » Apr 15 2019 2:10pm
I've been thinking about your battery layout, and I have some concern regarding the lack of compression applied to the individual cells. Every electric car battery I've disassembled has had compression force on the 2 faces of the cells. It is an important part of the battery structure affecting both capacity and cycle life.
Alexander1971   10 W
Post by Alexander1971 » Apr 16 2019 2:53pm
John in CR wrote:
Apr 15 2019 2:10pm
The aluminum case of the battery has good durability.
John in CR   100 GW
Post by John in CR » Apr 16 2019 7:06pm
Apr 16 2019 2:53pm
John in CR wrote:
Apr 15 2019 2:10pm
In my experience they all swell, and I'm talking about prismatics, not just pouch cells. At a minimum be alert for it and check early in the life for any changes with a caliper. If you notice a change, then make some wedges of a light but rigid material to fit in between with a tight fit when the pack is at a fairly deep DOD (The width dimension changes a bit with SOC).
Alexander1971   10 W
Post by Alexander1971 » Apr 22 2019 7:01am
Changed the winding scheme and filled with heat-conducting compound.
Alexander1971   10 W
Post by Alexander1971 » Apr 22 2019 2:18pm
:bigthumb:
