1984 Honda Elite CH125
FbGFxVQhO6UHmBZQU   1 µW
Post by FbGFxVQhO6UHmBZQU » Jun 03 2021 9:54pm
Hi. I'm hoping to change the old scooter to an electric. It is not easy to get a street legal e-scooter in my state so I hope retrofitting will work out. I'll update what is going on as it goes on.
original scooter
Really appreciate any advice too.
I hope to be able to reach 55mph in a pinch, so I've asked about 72V QS MOTOR.
I just got a quote for a motor and battery and parts. Does it look good?
Code: Select all
1pcsx QS V4 10inch 3000w drum motor wheel
1pcsx 72V150A sabvoton controller
1pcsx bluetooth adapter
1pcsx throttle with switch
1pcsx 12V dc-dc converter
1pcsx CT-22 hall display
1pcsx Alarm
1pcsx 72V10A charger
1pcsx 72V50Ah lithium battery (410x150x153mm)
These are parts preview.
Battery
72v battery 50ah
controller
controller
display
display
12 step down
12 stepper
QS
qs motor
Re: 1984 Honda Elite CH125
Post by FbGFxVQhO6UHmBZQU » Jun 09 2021 5:37pm
I got another estimate with a different battery size.
Code: Select all
1pcsx 72v QS V4 10inch drum brake motor wheel 100Kph possible speed
1pcsx 72V150A controller
1pcsx display for speed and battery charge
1pcsx Alarm (optional)
1pcsx 72V charger (USA Plug)
1pcsx 72V50Ah lithium battery (220x170x320mm)
I made a template and I think this battery size can work. What do u think?
Template 220x170x320 top
battery template top view
I'm sure I can grind down the frame some and make a nice box in there for this size battery to slide in and rest an inch or two above the frame into the former gas tank space.
Template 220x170x320 side
battery template
My idea is to bolt this Suzuki swing arm in there just above the parking stand. Is anything wrong with having the swingarm pivot a little lower than the rear axle? It looks like that is what will be the result.
kreal   1 W
Post by kreal » Jun 10 2021 7:56am
FbGFxVQhO6UHmBZQU wrote:
Jun 09 2021 5:37pm
If I understand correctly, then it shouldn't be a problem. You'll see this on most motocross bikes also.
Screenshot 2021-06-10 at 19.57.47.png (167.2 KiB) Viewed 63 times
Post by FbGFxVQhO6UHmBZQU » Jun 10 2021 8:41pm
kreal wrote:
Jun 10 2021 7:56am
thank you for advice. i think this low rider is really more like the case I will end up with.
the pivot will be lower than wheel axle. but surely not that much lower. it is very encouraging.
