Page 1 of 1
60V E 300 Hub Motor Project Underway
Posted: May 30 2019 8:45am
by detrailers
Dropped pan 2" to accomodate bigger batt and controller, still have 2" ground clearance. Also had to rework rear frame upright to accommodate disc and cally. Next up ill be making the mount for caliper and welding up unused holes and then final weld and grind and off to powdercoat.
Re: 60V E 300 Hub Motor Project Underway
Posted: Jun 04 2019 2:32pm
by pattyballs
How do you like that hub motor? I have one on the way too!
Posted: Jun 04 2019 4:00pm
by detrailers
Mine arrived slightly damaged and missing brake cable and throttle plug was incompatible with controller plug. Bought it from vendor on AliExpress and fortunately got a partial refund because Ali does cover your ass. Haven't had a chance to hook it up yet but was finishing the fab on the frame today and will be going to powdercoat soon....
Posted: Jun 11 2019 6:40pm
by detrailers
Metal work done. Added a gusset for the brake mount since kinda need brakes.... welded up un used holes, stripped and off to powder coat...
