j bjork wrote: ↑Jun 28 2020 11:04am
My charger has been working fine, so I went on and changed controller to the votol em 150sp I bought together with the motor.
The specifications are not very impressing with 380pA and 120bA, but luckily it is unlocked
I thought it wouldn't deliver good pA, but according to another members measurements it does.
And it sure feels like it does. I have it set up for 500pA and 300bA, just like I had on the nuc.
In sport mode this sure has a lot snappier throttle response, and better power at low rpm.
Just what I needed, the peak power has never been a problem so far
I made the brackets for the nucular 24fet. But when I understood that this controller may be interesting too, I modified them so both should fit. But it is not a very good fit on this controller. I would like to mount it further out, more in line with the seat. But that would mean cutting the old one off, and weld on a new one..
I don't feel like stripping the bike, paint and all that at the moment
Some other things to play with:
An 80 tooth rear and some 11 tooth front sprockets.
The 10 tooth I have now is pretty much worn down, and has a lot of play on the shaft.
I think these will be a tight fit, but were not available in 10 tooth.
I think it would be good to go bigger than 80 tooth rear for the gearing, but it is so damn big
A problem is that it is steel.. It will probably last forever, but I think it weighs 4kg..
It will need some serious lightening.
The bike worked very good today, but I crashed a few times.
At one time I broke my light switch:
I used the flasher switch as a 3 speed switch, with reverse, mid (or high, a bit confusing in the program) and sport.
It felt kind of broken, but stayed in sport so I could continue. I think I will just get rid of it, I don't really need high/low beam atm. anyway. I only use sport on the track, but I like to have reverse.
On the picture is also my button for regen, no variable regen on this controller unfortunately. But it worked pretty good so far anyway. It locks the wheel on loose ground, but I usually did that with the variable regen too. It just skids a little on big rocks, so it seems like I found a decent all-round setting.
What I miss the most from the nuc is the very nice display.'
Oh, and another thing. A guy at the track had a ktm freeride, and he let me test it. I was too tired atm to take it to the track, so I just took a quick spin on a dirt road.
And I can say that my bike sure felt more powerful than it, and definitely snappier
It was a bit to short test to say to much for sure, but that was the feeling I got anyway.
