KHB - Project eTurd - 2000W - LiFePO4 48V 24Ah
kreal   1 W
Post by kreal » Apr 02 2020 9:22am
So I finished my daily driver e-scooter: viewtopic.php?f=12&t=105234 and want a new project.
Welcome to Project eTurd:
I was thinking about using a QSMotor 3000w 13870h chain driven 14T front, 45T back, with 17inch wheels.
The only controller I have right now because of virus and shipping is halted is a generic no name 1500watt, however it goes up to 64v, so might be able to do 23amps!
My goal is to accomplish something like this:
Screenshot 2020-04-02 at 21.21.32.png (308.6 KiB) Viewed 2512 times
I will use the back from a Honda MSX, and the front from a Suzuki step 125
kreal   1 W
Re: Project eTurd QSMotor 3000w 13870h - 6x 12v 5ah Lead Acid
Post by kreal » Apr 04 2020 12:59pm
What would you suggest to have really good acceleration with the 3000w motor?
14T in front and 65T in back ?
The lead acid batteries I have for this can pump out around 60amps
kreal   1 W
Post by kreal » Apr 15 2020 3:33am
Coming along, it is a bit steep angle I manage to make for the front forks, but it might work just fine.
After all, it is project eTurd.
kreal   1 W
Post by kreal » May 06 2020 6:56am
Seat mounted, and some lights.
ShadowNightmares   1 W
Post by ShadowNightmares » Jun 10 2020 11:46pm
kreal wrote:
Apr 21 2020 5:36am
And motor mounted.
Is that an alternator?
momus3   100 W
Post by momus3 » Jun 25 2020 4:35pm
I think you'd better copyright that name. Might be stolen by some electric commode corporation types.
That's a good looking bike! I've been wanting to do something w/ those 12V 5AH batteries ever since I discovered that you can buy an 8 pack of them (see link below) for under $100, and that's delivered to my door. Might be just the thing for my eTrike project. Good job.
https://www.batterysharks.com/12-Volt-S ... s/1213.htm
Post by ShadowNightmares » Apr 24 2021 12:52am
kreal wrote:
Apr 21 2021 12:04pm
ShadowNightmares wrote:
Jun 10 2020 11:46pm
kreal wrote:
Apr 21 2020 5:36am
And motor mounted.
Yep, converted.
Wow, nice! Do you have videos running with it?
At least spinning it on the controller
Is the alternator coupled to hall or light sensors?
larsb   10 MW
Post by larsb » Apr 24 2021 6:43am
kreal wrote:
Apr 04 2020 12:59pm
1:7 is about right for wheel popping acceleration, coupled with a 500A (phase) controller. Those lead acids and that controller won’t do it if you want ”really good acceleration”
Elektrosherpa   100 W
Post by Elektrosherpa » Apr 24 2021 10:42am
I think you will not have much fun with 5Ah.
Simplified calculation:
3000W/72V -> ~40 A
So with your 5 Ah you can operate the motor at full power for at about 0,125 hours (1/8 of an hour)...
This is 7,5 Minutes, or 450 seconds...
I am also planning to begin with LeadAcid, but at least 20-30 Ah.
larsb   10 MW
Post by larsb » Apr 24 2021 10:58am
Why bother at all with lead acid? It doesn’t have enough performance for this motor which can take +20kW. A 72v 60A 5Ah pack will deliver too little in every way.
If looking for cheap then buy some chinese lipo or even better some used hybrid car cells. Lead acid is never worth it (unless you have unlimited space and weight. On a bike you don’t.)
I’d go as far as to say that the only place for lead acid these days might be in a home energy storage system (if you get the batteries for a very low price.) They don’t belong in EV:s anymore.
kreal   1 W
Post by kreal » May 14 2021 1:17pm
Still work in process, I think this might be the final reversion, just don't know if the shock is to steep?
Elektrosherpa   100 W
Post by Elektrosherpa » May 15 2021 4:38am
kreal wrote:
May 14 2021 1:17pm
Not sure about the angle of the rear shock. But I'd say its upper fixing point is designed too weak.
And in my opinion, the steering angle (front fork to frame) is way too flat...
kreal   1 W
Post by kreal » May 15 2021 6:03am
Elektrosherpa wrote:
May 15 2021 4:38am
kreal wrote:
May 14 2021 1:17pm
The rear shock fixing point will be reinforced with bunny ears.
kreal   1 W
Post by kreal » May 15 2021 3:45pm
Brake caliber added, and adjusted the shock for better angle.
Found a second hand foot brake, even though it's not really needed on a electric bike :)
I'm thinking a much larger battery could go here, as I see on many others, as I made plenty of ground clearance.
Motor will go here or similar I think.
Will most likely use the new one.
New-Arrival-QS138-70H-V3-72V-100kmph-Mid-Drive-Motor-with-1-2-35-gearbox-for.png_.png
New-Arrival-QS138-70H-V3-72V-100kmph-Mid-Drive-Motor-with-1-2-35-gearbox-for.png_.png (485.97 KiB) Viewed 857 times
Also made air intake for cooling in the front.
Screenshot 2021-05-16 at 04.21.15.png (1.15 MiB) Viewed 854 times
kreal   1 W
Post by kreal » May 16 2021 5:30pm
May 15 2021 4:38am
kreal wrote:
May 14 2021 1:17pm
Also will be reinforced with seat, like this.
Screenshot 2021-05-17 at 05.30.00.png (4.01 MiB) Viewed 801 times
kreal   1 W
Post by kreal » May 18 2021 3:17am
Seat welded:
Screenshot 2021-05-18 at 15.12.24.png (1.67 MiB) Viewed 765 times
Screenshot 2021-05-18 at 15.20.20.png (1.7 MiB) Viewed 765 times
stan.distortion   100 W
Post by stan.distortion » May 18 2021 6:02am
Interesting build but please bare this in mind for lead-acid:
https://en.wikipedia.org/wiki/Peukert%27s_law
Projects indirectly sponsored by https://www.dash.org/
kreal   1 W
Post by kreal » May 18 2021 9:54am
stan.distortion wrote:
May 18 2021 6:02am
Thanks, yeah I'm going with LiFePO4 instead, as they should be the safest type, in case I crash in the jungle.
Also I found this motor kit very cheap, the QS motor is to expensive still for this build.
around $130
However I am unsure of the AH I need for battery to support 2000w since motor is rated for 42A
I can get a really good and cheap 48v 12AH ( 16S-2P )
  • Battery LiFePO432650 3.2V 6Ah(6000mAh)
    Charge and discharge standard: constant current and constant voltage (CC/CV)
    Nominal voltage: 3.2V
    Charge upper limit voltage: 3.65V
    Lower discharge voltage: 2.0V
    Nominal capacity: 6000mAh (6AH)
    Measured capacity: 6000mAh or more (6A test)
    Maximum continuous charging: (1C 5A)
    Maximum continuous discharge: (3C 15A)
    Maximum instantaneous discharge: (5C 25A)
    Charging temperature (°C): -20~45
    Discharge temperature (°C): -20~60
    Storage temperature (°C): -20~35
But I guess I might need ( 16S-3P ) for a total of 18Ah to support a continuous discharge of 45 amps ?
kreal   1 W
Post by kreal » May 18 2021 2:34pm
A little progress:
Moved the hydraulic foot brake to new foot pegs.
Screenshot 2021-05-19 at 02.32.45.png (1.43 MiB) Viewed 718 times
kreal   1 W
Re: Project eTurd - 2000W - LiFePO4 48V 24Ah
Post by kreal » May 22 2021 3:32am
Battery ready.
16S-4P
This should give me 60A continuous and 100A instantaneous discharge, if my math is correct ?
So plenty of juice for motor at 42A / 48v = 2016watt
Could probably get a better controller and run it at 50A / 2880watt
Screenshot 2021-05-22 at 15.32.22.png (1.04 MiB) Viewed 596 times
kreal   1 W
Re: Project eTurd Motocross - 2000W - LiFePO4 48V 24Ah
Post by kreal » May 24 2021 10:05am
Battery box fabricated, half inside frame, half outside.
Screenshot 2021-05-24 at 22.04.05.png (1.03 MiB) Viewed 511 times
Also added massive disc brake for front wheel.
Screenshot 2021-05-24 at 22.04.41.png (1.54 MiB) Viewed 511 times
Seat also made. Not to sure right not about position, maybe I'll cut the frame shooter.
Screenshot 2021-05-24 at 22.04.59.png (1.5 MiB) Viewed 511 times
And new awesome handle bars, found for just $5
Screenshot 2021-05-24 at 22.05.22.png (764.43 KiB) Viewed 511 times
kreal   1 W
Re: Project eTurd Motocross - 3000W - LiFePO4 48V 24Ah
Post by kreal » May 26 2021 5:55am
much progress today.
Ready for paint
Screenshot 2021-05-26 at 17.50.56.png (808.59 KiB) Viewed 422 times
Screenshot 2021-05-26 at 17.51.03.png (846.62 KiB) Viewed 422 times
Screenshot 2021-05-26 at 17.51.08.png (741.63 KiB) Viewed 422 times
I found the best color I could for an eTurd.
Also added a bracket for front brake caliber today.
Screenshot 2021-05-26 at 17.49.09.png (1.65 MiB) Viewed 422 times
Screenshot 2021-05-26 at 17.49.14.png (1.52 MiB) Viewed 422 times
Screenshot 2021-05-26 at 17.49.21.png (1.04 MiB) Viewed 422 times
Screenshot 2021-05-26 at 17.49.27.png (1.95 MiB) Viewed 422 times
Screenshot 2021-05-26 at 17.49.36.png (2.01 MiB) Viewed 422 times
Screenshot 2021-05-26 at 17.49.42.png (1.64 MiB) Viewed 422 times
I do think it's going to be very fun to ride.
