KHB - Project eTurd - 2000W - LiFePO4 48V 24Ah
kreal   1 W
Re: KHB - Project eTurd Motocross - 3000W - LiFePO4 48V 24Ah
Post by kreal » May 27 2021 5:14pm
New knobby tires, and shorten the frame a bit.
Screenshot 2021-05-28 at 05.14.01.png (1.68 MiB) Viewed 332 times
kreal   1 W
Post by kreal » May 28 2021 5:10am
Really happy with the result so far, just waiting for 3000w motor.
Screenshot 2021-05-28 at 17.09.32.png (2.84 MiB) Viewed 316 times
Screenshot 2021-05-28 at 17.09.39.png (2.3 MiB) Viewed 316 times
Screenshot 2021-05-28 at 17.09.48.png (2.82 MiB) Viewed 316 times
kreal   1 W
Post by kreal » May 29 2021 6:13am
Added a little plastic leftover from my Yamaha nouvo elegance 135 lc conversion. Recycle to the max.
Also added some stickers, because why not.
Screenshot 2021-05-29 at 18.11.27.png (1.37 MiB) Viewed 292 times
Use an old mudflap I had from a scooter.
Screenshot 2021-05-29 at 18.11.32.png (1.82 MiB) Viewed 292 times
Screenshot 2021-05-29 at 18.11.38.png (1.84 MiB) Viewed 292 times
kreal   1 W
Post by kreal » Jun 04 2021 1:43pm
Motor and controller mounted.
Screenshot 2021-06-05 at 01.35.18.png (644.98 KiB) Viewed 237 times
Screenshot 2021-06-05 at 01.31.21.png (2.05 MiB) Viewed 237 times
Screenshot 2021-06-05 at 01.33.55.png (1.78 MiB) Viewed 237 times
However this motor has no torque whatsoever, even with a very big 46T sprocket on the back, and 14T in front using 520 chain. I kinda knew that.
Although it has plenty of rpm. But how do I fix more torque, some sort of gearbox ?
14T to 50T to 14T to 47T ?
Screenshot 2021-06-05 at 01.42.41.png (64.34 KiB) Viewed 237 times
ShadowNightmares   1 W
Post by ShadowNightmares » Jun 04 2021 1:59pm
kreal wrote:
Jun 04 2021 1:43pm
However this motor has no torque whatsoever, even with a very big 47T sprocket on the back, and 14T in front using 520 chain. I kinda knew that.
Yep, you will need a jackshaft
Your desired 14T>50T/14T>47T will have final ratio of 11.99:1
So with 4k RPM in the motor, the wheel RPM will be 333RPM, with 24inch tires (on 18inch wheels) will have 23,8MPH
kreal   1 W
Post by kreal » Jun 04 2021 2:05pm
ShadowNightmares wrote:
Jun 04 2021 1:59pm
kreal wrote:
Jun 04 2021 1:43pm
So with 4k RPM in the motor, the wheel RPM will be 333RPM, with 24inch wheels will have 23,8MPH
thanks, didn't know what it was called, I'll search for jackshaft, see if I can make one.
wheels are 17 inch 80/100.
23,8MPH is fine, as long as I can claim a few hills :)
kreal   1 W
Post by kreal » Jun 04 2021 2:19pm
I do have another 14T and 45T sprocket, I could make jackshaft from.
Motor - input jackshaft - output jackshaft - wheel
14T -> 46T -> 14T -> 45T
Would give 20.66MPH with 17Inch tires, and a gear ratio of 10.56:1 as the motor has a rated RPM of 4300
However I have no idea if this would provide enough torque ?
Post by ShadowNightmares » Jun 04 2021 3:05pm
kreal wrote:
Jun 04 2021 2:19pm
You need to calculate the speed using the diameter from the tire, not the wheel
About the torque, 14T>46T is 1:3,28, so the jackshaft will give you ~3x more torque than you have at the moment
kreal   1 W
Post by kreal » Jun 04 2021 6:08pm
Jun 04 2021 3:05pm
kreal wrote:
Jun 04 2021 2:19pm
Sounds really good. Made the jackshaft already. 46T -> 14T
Screenshot 2021-06-05 at 06.07.25.png (1.19 MiB) Viewed 213 times
rynhardt   1 W
Post by rynhardt » Jun 05 2021 4:47am
If you use a chain with a smaller pitch, you can get larger ratios. Have a look at the OSET bikes for example.
I'm using #219 (gokart) chain, with a 10T front and 121T rear.
kreal   1 W
Post by kreal » Jun 05 2021 10:39am
rynhardt wrote:
Jun 05 2021 4:47am
Thanks! just can't seem to find sprockets this size around here. Was looking at aliexpress.com, but couldn't find.
I do have a 11T - 420 chain for motor. But still need to find a giant back sprocket then.
The best I can find is 74T for T8F chain.
https://www.aliexpress.com/item/4000780 ... hweb201603_
Oh and my jackshaft failed miserably.
kreal   1 W
Post by kreal » Jun 07 2021 12:05pm
So this is what I came up with. Should work ok.
Drilled a hole in the swing arm, and added two barrings to support the jackshaft.
Screenshot 2021-06-08 at 00.03.59.png (2.2 MiB) Viewed 137 times
Screenshot 2021-06-08 at 00.03.50.png (2.01 MiB) Viewed 137 times
Should give me 9:1 in which if I understand correctly is plenty of torque.
Screenshot 2021-06-08 at 00.00.35.png (51.13 KiB) Viewed 137 times
Sadly cannot finish today, it's to late and I cannot make noise cutting the chain to length.
The quality of the bike is very questionable, but hey it's project eTurd. And just me trying out stuff on the bike in preparation for next proper project.
stan.distortion   100 W
Post by stan.distortion » Jun 07 2021 1:47pm
Looks like the pigeons are getting out of hand in your shed! ;) Ingenious... terrifying but ingenious. Will your shock still clear when it compresses? And in that speed/ratio calc, doesn't have to be the total height of the tire? I'm guessing 17 is just the rim size but can't make out the tire markings.
Projects indirectly sponsored by https://www.dash.org/
kreal   1 W
Post by kreal » Jun 07 2021 5:32pm
stan.distortion wrote:
Jun 07 2021 1:47pm
heh, Still trying to find a donor motocross bike around here. But almost impossible. So had to make my own out of steel.
Unknown if the shock will clear if I bottom out. But me jumping up and down hard on it seems alright.
The motor is still quite a bit under the back tire. So should be alright.
True, I don't know quite how to calculate it, wheels are 17 inch 80/100. Then it should be 23.3 inches ?
kreal   1 W
Post by kreal » Jun 10 2021 8:19am
So final result.
Screenshot 2021-06-10 at 20.17.37.png (1.45 MiB) Viewed 90 times
Don't look at the welding on the motor. The sprocket kept falling off, and I got tired of it.
Screenshot 2021-06-10 at 20.17.21.png (2.93 MiB) Viewed 90 times
It works pretty good with a gear ratio of 14T -> 42T 420 chain -> 14T -> 46T 520 chain.
9.86:1
Top Speed: 29.94
Post by stan.distortion » Jun 10 2021 8:55am
Result! :bigthumb:
