Electric "tough bike"
Show off your E-Scooter or Motorcycle creation here.
vax   100 W
Re: Electric "tough bike"
Post by vax » Jun 26 2013 5:16am
Prototype fabrication https://www.facebook.com/3dflux
mushymelon   1 kW
Post by mushymelon » Jul 07 2013 12:14pm
Looks great.
You may want to consider more reinforcement up front.
Cheers
Mushy
vax   100 W
Post by vax » Jul 27 2013 10:04am
Some porn.
There was quite a hassle with frame welding. At first try the rear arm ends bent inwards, so we made vertical cuts to already welded arms, bent them straight, welded support plates to keep them parallel and then at last welded the cuts together. And the whole frame spent some hours at oven @ 220C for stress relief. Today I cut support plates away and it stayed parallel.
Ther's rear suspension missing entirely yet, this, and rear dropouts are next big jobs.
jansevr   1 kW
Post by jansevr » Jul 27 2013 10:17am
wow - its looking awesome! very nice welds as well =) whats the weight at as pictured above?
pendragon8000   1 MW
Post by pendragon8000 » Jul 28 2013 5:28am
vax wrote:Some porn.
Awesome.
What do you think of geometry?
Small 20" wheels? Hard to tell what it would be like to ride, I suspect nimble and plush.
Btw awesome 3d triangulation of the swing arm. Very cool
sk8norcal   100 MW
Post by sk8norcal » Jul 30 2013 11:35pm
looks good,
never ridden motocross bikes,
but seems like ur peg position is off...
ideally peg position be adjustable, no?
vax   100 W
Post by vax » Aug 01 2013 9:30am
All I can say right now, that seating position will be more mtb than mx.
The saddle will also be mtb one, the saddle post attachment point will be at the top of "pylon".
Right where are two bolt holes, seatpost bracket will be between them.
torqueboards   100 MW
Post by torqueboards » Aug 28 2013 12:23am
That's an awesome frame. Amazing work. Sure beats the price of those expensive ebikes. Reallly Really Great bike. I've been lurking the E scooter/ebike posts and man the E Bikes are ridiculous.
Sweet build. Wonder how a 72v would be.
DIYElectricSkateboard.com Electric Skateboard Kits
vax   100 W
Post by vax » Sep 11 2013 11:50am
I'm currently messing around with rear suspension linkage, basically it will amplify movement of rear swingarm, progressively.
Partly, because I found that my rear spring was too weak for my weight :D
oatnet   10 MW
Post by oatnet » Sep 11 2013 11:55am
Just came across this - I've been working on a similar design, I look forward to seeing where you take this!
-JD
Member 117 of 26,000+
153v DUNE BUGGY © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler FrictionDrive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
Knowledge is acquired through experience, everything else is just information - Albert Einstein
"Cheater?" I'm not competing, I'm Commuting!
meelis11   100 W
Post by meelis11 » Sep 12 2013 2:46am
Nice looking, has lots of potential. But that 250W hub seems little underpowered for ebike with looks like this.
First thing is to get it running, can upgrade later if you need more power :)
I want to see it when it is running, I am from Tallinn :)
Meelis
vax   100 W
Post by vax » Sep 15 2013 9:34am
About 250W hub:
It's all about being street legal. In real life I'm sure it can handle much more power. Also, I'm using 48V instead of 36V marked on the hub.
There's some issues, however. For example, I have to upgrade wires, current ones are really thin and will cause problems.
If I blow the motor, I can rewind it with thicker wire and less turns.
vax   100 W
Post by vax » Oct 16 2013 1:47am
Updates:
Installed rear shock
Installed front brake, 203mm disc with Avid Code 4 piston caliper
vax   100 W
Post by vax » Oct 22 2013 1:56pm
Front brake assembled.
Avid Code caliper with 203mm disk.
vax   100 W
Post by vax » Nov 16 2013 12:22pm
Rolling chassis.
Faults:
1. Rear spring too soft
Where to obtain? I reckon pitbike spring will be ok
2. Both tires flat, forgot to use spoke rubber ring...
3. Rear swingarm needs new bearings and proper assembly.
Next, I guess, will be electrical assembly.
There also will be small 40cc range extender.
dr_frost_dk   1 W
1 W
Post by dr_frost_dk » Nov 19 2013 10:26am
Bookmarked!.
My DM50 is fun as a conversion but it is truly awesome to see a PURPOSE built EV, Awesome job so far :), Looking forward to see it go when you get it finished.
vax   100 W
Post by vax » Dec 22 2013 9:00am
Did first ride today.
I manged to fry one of the BMS boards, I'll get a new one tomorrow, costs 14EUR...
So, today, I hooked up temporary wiring and headed to street. It was wet and cold, so I only did couple of Kilometers.
As I suspected 20A @ 48V is not very thrilling ride. So, 50A controller with better motor will be next goal.
Said that, I must admit, that the chassis is success. It handles very nimble, suspension stiffness just the way I like it.
It's quite long frame and seating position is pretty foward leaning. Add very hard saddle, meaning it's not very comfy ride.
jansevr   1 kW
Post by jansevr » Dec 22 2013 1:03pm
looks good! glad to see you finally have a running bike! you definitely need to get a more powerful motor - how about a cro motor :D and a different seat would probably be a good idea too. also i might have missed this at some point - but whats the capacity of the batter pack?
vax   100 W
Post by vax » Jan 01 2014 6:42am
jansevr, the battery is 20Ah.
Yes the motor is not very powerful, and it is slow too - must be low RPM motor. It doesn't go faster without load...
However, 1kw Kelly and motor doesn't get warm at all. Motor has 250W printed on side cover :) Maybe 50A kelly next?
I'll have a look on Cromotor.
ricklearned   100 mW
Post by ricklearned » Jan 01 2014 8:13am
Looks like those BMS boards could short on opposite battery terminal. Have you considered a centralized BMS?
100volts+   10 kW
Post by 100volts+ » Jan 01 2014 11:48am
subscibed
http://endless-sphere.com/forums/viewto ... =1&t=57440
Unlike puppets we have the possibility of stopping in our movements,
looking up and perceiving the machinery by which we have been moved. In this
act lies the first steps towards freedom. - PETER BERGER Sociologist
angelo212   1 mW
Post by angelo212 » Jan 20 2014 9:41pm
That is a beautiful work you did. Subscribed.
Wife rant: It was dark! you drank how many? 10 beers! How much more power do you have than you should? 40 times! How did you fall off? wheelstanding again! What were you thinking?
Zappy: How much fun it was.
vax   100 W
Post by vax » Jan 27 2014 1:26am
ricklearned wrote:Looks like those BMS boards could short on opposite battery terminal. Have you considered a centralized BMS?
Yes, I thought that could happen, and put extra insulation under bms boards.
Updates,
I'm currently building proper electric systems - solid state relays for switchoff, Dc-Dc for 12V systems.
The bms main board uses 12v since it' designed for cars.It has two 2A relays, that switch over, when one of the slave boards breaks loop circuit. I'm gonna use one of relays to feed the bms itsself (with parallel ignition switch) and other to drive main solid state relay. This way, when bms disengages relays, it's gonna auto-shutdown.
vax   100 W
Post by vax » Feb 13 2014 3:29pm
I published the project files to GrabCAD.
https://grabcad.com/library/electric-mo ... onocoque-1
vax   100 W
Post by vax » Feb 15 2014 6:23am
Designed stainless steel (0.8mm) side covers couple of days ago, they are being fabricated right now.
There will be foam insulation inside, both for temperature and electrical.
