YZF600R Thundercat EV
Show off your E-Scooter or Motorcycle creation here.
Bernel   100 W
Post by Bernel » Feb 03 2013 4:01pm
Hi all, new to this forum stuff, I took the plunge to convert my 1999 Thundercat to all electric when I lost second gear. I started the process in March 2012, lost of web research. I thought I was being innovative until I realised ev conversions had been going on for years. Any how here are my specifications.
ME0913
KHB72601
Kelly DC/DC converter
72V10A Charger
LiPo Pack 20S7P 74V 70Ah
Jay64   1 MW
Re: Thundercat EV
Post by Jay64 » Feb 05 2013 12:33pm
Sounds like a cool build. Where are you located? We didn't really call them Thundercats too much in the US. For those who are not familiar, this is the ZYF600R. This bike was the upgrade from the FZR and led to the R6. How far along are you on your build? Post some pics, we are looking forward to seeing this build.
Johnson64.Com "The stone age didn't end because we ran out of stones."
EV Bikes:
'13 Zero S 11.4kwh.
GS500, ME0913, Sevcon Size 6 Controller, 90v40ah Lipo, GSXR suspension..
'87 Hurricane 600, ME0709, 48v/50a SLA, Kelly KD72400, Magura Throttle, High Current Cycle Analyst.
http://www.evalbum.com/2275
Raleigh beach cruiser: 9C rear hub, stock controller, 48v10ah lithium, Cycle Analyst.
Phat Chopper: 9C front hub, stock controller, 48v12ah a123s, Cycle Analyst.
Bernel   100 W
Re: Thundercat EV
Post by Bernel » Feb 05 2013 8:19pm
Hi Jay64, I am in the UK we are a fair bit behind with diy ev's. I will post some pics of my progress soon. My current status is 12V wiring complete, took delivery of my charger yesterday and waiting for my battery box to be fabricated. I did a lot of mock Ups with foam and cardboard. So a few more slabs of aluminium and some welding and I should be good to go.
Will keep you posted, no pun intended.
Jay64   1 MW
Re: Thundercat EV
Post by Jay64 » Feb 05 2013 9:33pm
We've had a few brilliant builds come our way from the UK. Looking forward to what you come up with. You should try to meet up with Jeremy Harris and Jozzer to see what they have come up with. Two really great guys.
EV Bikes:
'13 Zero S 11.4kwh.
Bernel   100 W
Re: Thundercat EV
Post by Bernel » Feb 08 2013 10:57am
Hi Jay64,
I bought a charger off Jozzer's website and saw his video on Youtube I think, seems like a good guy. Don't know who Jeremy Harris is though?
Jay64   1 MW
Re: Thundercat EV
Post by Jay64 » Feb 08 2013 11:18am
Yeah, Steve (Jozzer) is a real good guy. Both of them are members here on this forum. You can search out some of their stuff by their user name in the author part of the search function.
EV Bikes:
'13 Zero S 11.4kwh.
jonescg   1.21 GW
1.21 GW
Re: Thundercat EV
Post by jonescg » Feb 08 2013 10:13pm
Don't worry, we called them Thundercats in Australia too. A very nice bike to ride actually.
John in CR   100 GW
Re: Thundercat EV
Post by John in CR » Feb 09 2013 9:57am
Do you already have your batteries? With a pack that size consisting of cells of a chemistry where an issue with 1 cell can cause a thermal runaway of the entire pack in less than a minute, be sure you understand the precautions required. It boils down to making sure no faulty cells make it into the pack, and make sure each cell can neither be discharged to too low a voltage or charged to too high a voltage, and they will serve you well.
Can't wait to see pics.
John
Bernel   100 W
Re: Thundercat EV
Post by Bernel » Feb 14 2013 3:00pm
Thanks all for the responses, I though I would post some pictures of what I have done so far.
Battery mock up
Controller layout
Motor mount
It's amazing what you can achieve with some cardboard and MDF, CAD takes too long for me. I am waiting for the battery box to be fabricated once that is done I will get it welded to the frame and build on top. I have ordered some auminium sheet and plate to replace the MDF once I am happy with where everything is going go.
I was looking at making my own charging point or EVSE as it is called in the UK, turns out in East Anglia you can get one installed for free, all they want in return is the ability to capture data of usage.
I will keep you posted on further events.
Bernel   100 W
Re: Thundercat EV
Post by Bernel » Feb 17 2013 10:27am
I though I would show my build history to date, here go's.
11/03/12
My Thundercat lost 2nd gear so decided to do an EV conversion. Here are some picures of the naked bike.
Naked from the right
Engine removed, what a mess!
Bernel   100 W
Re: Thundercat EV
Post by Bernel » Feb 17 2013 10:32am
From various forums and websites I worked out how I was going to mount the motor.
Motor mounting template made of MDF
Bernel   100 W
Re: Thundercat EV
Post by Bernel » Feb 17 2013 10:47am
I was initially going to use GBS batteries and decided to go for 6 x 100Ah, this would give me 72V and plenty of range. I bought some foam cut to the dimensions of the batteries, controller, dc/dc converter and charger that I was going to use.
Mock up with foam
With fairing on
Bernel   100 W
Re: Thundercat EV
Post by Bernel » Feb 17 2013 10:52am
The GBS 100Ah batteries were too big, I wanted to be able to fit the fairing back on to have the bike looking stock.
I ordered some more foam to the dimensions of the 60Ah batteries, these fit perfectly.
Front view
Side view with proposed bracing drawn on
Bernel   100 W
Re: Thundercat EV
Post by Bernel » Feb 17 2013 10:56am
Now that I had batteries that would fit I set about making mock up trays. I ordered some kraft board as mock up angle. It was so easy to work with cardboard and you can actually see how it all fits. This was my final design with these batteries.
Bottom tray
Bottom tray with 2 batteries
middle tray
Middle tray with 3 batteries
Top tray
Bernel   100 W
Re: Thundercat EV
Post by Bernel » Feb 17 2013 10:58am
This was the way the batteries would have been fitted in sequence but after all that effort mocking it up the cost to import them to the UK was way too expensive.
Top tray with single battery
Battery pack finished
Bernel   100 W
Re: Thundercat EV
Post by Bernel » Feb 17 2013 11:00am
We are now 25th of August 2012, my ME0913 has arrived, what a beast of a motor, here it is next to the engine.
Big difference in size
Bernel   100 W
Re: Thundercat EV
Post by Bernel » Feb 17 2013 11:03am
With the motor in my possession I set about designing the mounting bracket. I used MDF and dimensions from the drawing to measure it all out. My skill with a protractor and Pythagoras helped a lot here.
Here was the initial design.
Fits like a glove.
Bernel   100 W
Re: Thundercat EV
Post by Bernel » Feb 17 2013 11:08am
I was going to use 6mm aluminium for this mount and when I tested the motor by hand with the chain I noticed a lateral twisting force. Then I remembered Elgixer made some C plates for his AC20. I set about designing my own out of MDF again but it will be 12mm aluminium to take the clamping bolts.
My brother got a company to make the motor mounts for me. The front face plates arrived first and it fitted like a glove.
Motor mount
Fitted to the bike, sweet!
Bernel   100 W
Re: Thundercat EV
Post by Bernel » Feb 17 2013 11:12am
We are now 16th December 2012, I have the motor mounted, I have the controller, contactors, emergency disconnect, throttle pot box and various connectors. I cut out some 6mm MDF to mount the controller, throttle and contactors and placed them inside the frame.
Controller mounting
Bernel   100 W
Re: Thundercat EV
Post by Bernel » Feb 17 2013 11:15am
Next I began working out how I was going to connect the throttle cable to the pot box. I decided against the Magura twist grip as I did not want to mess around with the right hand handle bar. I put pencil to paper and came up with a simple design.
Design sketch
Mocked up bracket out of MDF
Throttle cable connected
Bernel   100 W
Re: Thundercat EV
Post by Bernel » Feb 17 2013 11:17am
The MDF plate and throttle bracket will be made from aluminium. I shot a video of the throttle in action and I will post it once I have worked out how to do it.
Jay64   1 MW
Re: Thundercat EV
Post by Jay64 » Feb 20 2013 11:31am
Looks very similar to one of my builds. Unfortunately I used a sevcon controller and the company I bought it from couldn't program it correctly. Regret not going with a Kelly.
EV Bikes:
'13 Zero S 11.4kwh.
Bernel   100 W
Re: Thundercat EV
Post by Bernel » Feb 20 2013 6:16pm
Hey Jay64,
And there was me thinking I was doing something original;-). It is interesting how things come together I started my design with no external input and when I discovered the EV Universe all the questions and queries I had were already answered.
Any way my aluminium plate arrived today and I have designed my own bus bars. Still waiting on the battery box though.
I would be interested in seeing your similar build, have you got a link to it?
Jay64   1 MW
Re: Thundercat EV
Post by Jay64 » Feb 20 2013 6:36pm
Well, I used a different chassis. But here is my build thread.
http://endless-sphere.com/forums/viewto ... 10&t=38221
It started off with a totally different design idea, and then ended up becoming closer to your build.
EV Bikes:
'13 Zero S 11.4kwh.
Bernel   100 W
Re: Thundercat EV
Post by Bernel » Feb 25 2013 1:29pm
I have given up on the video of the throttle cable in action, I am sure I will work it out later.
So back to the build, 24th December 2012 I set about mocking up the new battery tray which will house the LiPo batteries.
Mocked up with cardboard
In situ
Revised mounting arm to frame
