Grinhilia - my Aprilia RS125 Conversion
RIPPERTON   100 W
Re: Grinhilia - my Aprilia RS125 Conversion
Post by RIPPERTON » Apr 16 2015 5:19am
They are just casting marks Jay
Andy you will still need to run a tube between the swingarm bearing inner races over the exposed part of the swingarm axle.
So the screw in the right frame can push the swingarm over to the left without flexing it.
My 2 short pieces of SW axle thread into the 2 alloy plates so they are effectively held either side of each bearing.
The 2 alloy plates still need to be welded to the frame
Grinhill   10 kW
Post by Grinhill » Apr 17 2015 2:31am
You mean like this one I made the other day... :wink:
Bored to 14mm, outer diameter 30mm, length 93mm.
Spacer sandwich to get the motor plate in just the right spot.
Fits nicely. I will use the small square block as part of a bracket to hang the controller from.
1995 Giant Hybrid - Zeta2 with 12V 7AH SLA - removed after one year.
2006 Converted Giant to Geared Brushless Rear Hub with 24V 17AH SLA - bike stolen 2007.
2008 Hardtail MTB Disc Brake - lightweight RC/LiPo system.
Grinhill's Medium-power RC-Motor Hardtail build
The Grinhill Mk2 RC-motor drive
Grinhill III - "Supercommuter" featuring Recumpence RC drive
RIPPERTON   100 W
Post by RIPPERTON » Apr 21 2015 4:28am
That spacer looks suspiciously like steel in the first shot but bright like alloy in the second shot.
Stick with alloy there is a Capral aluminium place in Minibung rd Cardiff that sells offcuts, not sure about rounds though.
That spacer will work but would be heaps better if the motor was back.
team_EMUS   10 mW
Post by team_EMUS » Apr 28 2015 6:00pm
Was the project ever finished?
Grinhill   10 kW
Post by Grinhill » May 01 2015 8:25pm
Not yet! Still slowly working on it.
RIPPERTON   100 W
Post by RIPPERTON » May 09 2015 3:34am
Vario kind of works, goes round but needs a lighter spring in the driven pully to upshift at 4k rpm.
https://www.youtube.com/watch?v=7heqNp-qlQc
Ohbse   10 kW
Post by Ohbse » Jul 12 2015 5:27pm
Any progress?
I've seriously been eyeing up an Emrax 207 for my next build, it's very difficult to beat the power to weight - even taking into consideration the mounting complexity. There are now a couple of quite good punchy low voltage controllers which mean I could achieve my weight target with low complexity. What do you think of it so far?
Toby82   100 mW
Post by Toby82 » Jul 14 2015 2:15am
Hi Ohbse,
Yeah the Emrax 207 LV is looking good for my build also. I have just made some enquires to both enstroj and Emsiso regarding the low voltage setup. I started a thread in escoots/motorcycles general discussion folder http://endless-sphere.com/forums/viewto ... 10&t=70967 but it seems no one on ES has used this setup before. I'll update my thread with Info regarding the setup once I hear back about my enquiry. Which controllers are you considering?
Cheers,
Grinhill   10 kW
Post by Grinhill » Jul 15 2015 1:56am
That would be great to see, I also seriously considered the 207, it would be ideal in the aircooled version for an even lighter weight (no cooling components), and a few mm smaller diameter makes fitting batteries that much easier. I'm sure there would be a suitable Sevcon controller for it also.
There's been some slow progress, a little at a time.
Here's some shots of a test fit with the actual Rinehart rather than a wooden one! The lower fairing fits nicely around it.
Next was a plywood battery box to test fit.
jonescg   1.21 GW
1.21 GW
Post by jonescg » Jul 15 2015 4:06am
I love the placement of that controller down there. It's a bugger the PM150 is that much longer, otherwise I'd have placed Voltron's controller down there too.
How's the plywood pack fit?
Grinhill   10 kW
Post by Grinhill » Jul 15 2015 7:38pm
Hey Chris thanks for your assistance with battery box design. The first attempt based on this sketch shows the battery box in front of the controller, but it protruded in front of the fairing a little and I wasn't happy with the front wheel clearance.
So I lifted the box above the front of the controller, which allowed the box to be a bit more vertical. This leaves plenty of room for wiring and ancillaries in front of the controller, with the downside being that the CofG goes up a little.
I'm happy with the location now, the maximum external width of the box is 178mm with the limiting factor being the subframe rails which taper inwards at the rear of the battery box. The front of the box is also very close the frame. There's some room to play with the height as there's plenty of clearance to the tank cover.
Ohbse   10 kW
Post by Ohbse » Feb 02 2016 7:33pm
How's the project going Grin? Been 6 months, hope you haven't dropped off the map :)
macribs   1 GW
1 GW
Post by macribs » Feb 13 2016 12:18pm
Subscribed. Hope to see this build completed.
Grinhill   10 kW
Post by Grinhill » Feb 18 2016 12:56am
Hi guys, project still going but very slow progress, keeping busy with other things.
I don't get over to ES very often either.
cheers.
MuddyGamer82   100 µW
100 µW
Post by MuddyGamer82 » Feb 26 2016 3:40am
keep up the good work! looks very interesting
Samd   1.21 GW
1.21 GW
Post by Samd » May 08 2016 11:01pm
Sub'd. Recently bought a complete RS125 with ME1114 installed from a guy in Sydney and now about to start compliance work...
http://ballaratebikes.com/
