Project Blue Smoke - Aprilia RS conversion
Show off your E-Scooter or Motorcycle creation here.
-UP-   100 mW
Re: Project Blue Smoke - Aprilia RS conversion
Post by -UP- » Sep 09 2015 2:39pm
It's the stardard version
You can find the Project Blue Smoke on Youtube, Tumblr and D_TRB
riba2233   1 MW
Post by riba2233 » Sep 09 2015 2:48pm
that's really nice! Can you please take a picture without that effect, both controller and motor look very small lol
-UP-   100 mW
Post by -UP- » Sep 12 2015 1:28am
Here's new pic with less bokeh.
riba2233   1 MW
Post by riba2233 » Sep 12 2015 7:47am
Thanks, motor looks very nice, this should be a blast to drive :)
newbiebiker   100 mW
Post by newbiebiker » Sep 15 2015 2:36pm
you decided for mid drive (driven by belt or chain)
Dream - hybrid bike (normal petrol bike + front wheel hub motor)
-UP-   100 mW
Post by -UP- » Sep 16 2015 1:22am
I'll go with 520 chain, so I can keep the original rear sprocket (might change the teeth count). The shaft of the revolt motor is machined so that I can use JTF337 sprocets. This gives me option from 12 to 15 theeth front sprocket.
-UP-   100 mW
Post by -UP- » Jan 11 2016 2:44am
I recorded this footage before we got snow in Finland. I had just received the motor and wanted to see how it would fit on the RS frame. Next step is to build the mount for it, then I can have my first test runs! It'll have to wait until spring/summer, since I don't have any warm place to work on the bike.
I've been also working on an eBike as a side project (1kW front hub motor). There are some things that I can utilize also on the Aprilia. Plans are getting clearer regarding the charger, dash and BMS. One thing to decide is that should I buy a smaller, cheaper battery first to test the Aprilia and then later use on the eBike, or buy the big heavy battery pack right away.
-UP-   100 mW
Post by -UP- » Jun 05 2016 4:58am
I got the motor mounted. Then I mounted the controller with zip ties and connected a small LiPo pack. Controller configured with lowest current settings for this first test. Next I'll have to start working on the mounts for the controller and battery, also finish the motor mount.
E-Chopper   10 W
Post by E-Chopper » Jun 06 2016 7:04am
Nice Ride !!
Greetings
Martin
"Thunder is good,Thunder is impressive;
but it is Lightning that does the work !
-Mark Twain
riba2233   1 MW
Post by riba2233 » Jun 06 2016 7:47am
So, how does the motor behave? Does it heat up? Is that short or normal version?
-UP-   100 mW
Post by -UP- » Jun 06 2016 9:08am
That's the normal version. I tuned in a bit more power, did few "fast" laps and one lap with rear brake applied. Couldn't feel any heat on the motor. Let's see how it handles more power later, feels good so far.
Ypedal   100 GW
Post by Ypedal » Jun 06 2016 9:17am
well done !!!.. 8)
ES site status page:
-UP-   100 mW
Post by -UP- » Jun 21 2016 5:53am
I've been thinking about the BMS. I want a system that enables me to read voltage of each sell to an Arduino and I can then play around with the data. Then I need some sort of balancing (thinking about bottom balancing) and overcharge control. My battery back is 24s Lipo, but I might replace it with larger LiFePo4 pack in the future.
Any suggestions what BMS to use?
macribs   1 GW
1 GW
Post by macribs » Aug 28 2016 2:55pm
Any more work done over the summer?
Just2807   10 W
Post by Just2807 » Aug 30 2016 6:23am
Yeah i am waiting for an update too, been folowing your project on yt too. :)
-UP-   100 mW
Post by -UP- » Aug 30 2016 9:33am
I wish I'd have more to show you.. Mainly I've been building the battery box that still isn't finished. More about that later..
I purchased a "new" frame, since they would have required full EMC measurements of that 2003 frame. So I'll transfer everything to 2001 frame. I'll keep the original speedometer, so that I don't have to prove the accuracy of my hall-sensor based speedometer. I'll add some kind of display for amps and other parameters. Now I'm thinking to have a separate battery for the lights, contactor, horn, controller and electronics, so no DC-DC. It would be awesome to get the bike to dyno still this year, but we'll see..
Manny   10 W
Post by Manny » Sep 09 2016 9:15am
hey nice project
i will start my aprillia rs50 conversion soon.
i was wondering where you live, because of the EMC required. in The Netherlands the data limit is on 1-1-2006 if i am correct.
-UP-   100 mW
Post by -UP- » Sep 13 2016 2:52am
Thanks. I leave in Finland. Here the limit is June 2003 and my first frame was first registered in July 2003... Will be an "interesting" challenge to register the bike. Hopefully I can do it next year.
I tried to edit a short video, but Kdenlive that I use for editing keeps crashing..
-UP-   100 mW
Post by -UP- » Sep 14 2016 3:58am
I was working on the brakes yesterday in a hope that if I'm able to do more test runs still in September or October (before snow), I would have working brakes. The seller of the frame told me that he wasn't able to bleed the front brake. I replaced the fluids and didn't have problems bleeding it. Then I started working on the rear brake and got problems. First I accidentally left the reservoir empty, then the master cylinder started to leak. Now I'm thinking if I should order the rear brake master cylinder rebuild kit, or just open and clean it and try to bleed again..
The battery box is pretty much riveted together. Next I need to solder the connectors to the batteries and make the battery-contactor-controller wires. Then temporary mount for the controller, 24V battery and wiring. Then it would be ready for a short track test or dyno run to get the papers for registration. If either of these happen, I'll post a video ;)
-UP-   100 mW
Post by -UP- » Oct 10 2016 11:48am
I have issues with my computer and can't edit a video, so I posted a blog about the first track test:
http://projectbluesmoke.tumblr.com/post ... motorcycle
-UP-   100 mW
Post by -UP- » Oct 19 2016 1:40pm
I was able to fix my computer and edit the video of the first track test session. Please enjoy:
marcexec   1 kW
Post by marcexec » Oct 24 2016 7:03am
Lovely video - great editing!
What was the top speed on the track?
Edit: could you measure the winding resistance on the motor and add it to https://endless-sphere.com/w/index.php/ ... _Selection? PM me if you want to "adopt it" :)
A motorcyclist is never late, Frodo Baggins. Nor is he early. He arrives precisely when he means to.
My Suzuki RF400 build: now with Enertrac MHM602 and 6kWh AESC modules protected by a Zephyr BMS
Renault Equation modded to 10S6P recycled laptop 18650s & 1kW controller.
Master of Electric Motor Selection: "Adopt a motor" (PM me if you have trouble editing)
All the gear, all the time!
-UP-   100 mW
Post by -UP- » Oct 25 2016 12:22am
My top speed was 87km/h (54mph) according to GPS. Had to be gentle on the throttle as the battery voltage was sagging. Given a longer straight it would have gone faster. I'll measure the winding resistant at some point.
-UP-   100 mW
Post by -UP- » Mar 19 2017 4:33am
I decided to build my own BMS using TI's bq76pl536a chip.
-UP-   100 mW
Post by -UP- » May 05 2017 9:28am
I'm facing an issue with my BMS. I have now two modules assembled and working. I was able to balance the 12s pack of my eBike. Then when I plugged in the charger negative terminal, the BMS went haywire. It doesn't happen when just one module is used. I tried to tune the RC low-pass filter to 16 Hz, but didn't help. Any ideas?
