Suzuki GSX-R e899 K2
Show off your E-Scooter or Motorcycle creation here.
Rovii   1 kW
Re: Suzuki GSX-R e899 K2
Post by Rovii » Feb 24 2020 3:31am
Got it trailered with 6” over series and can go another 5” over!
:lol: :lol: :lol:
Andre
- Fastest speed record 200,49 kph on flat after 740m (175V, 400A, Kelly KLS 8080I 14401, 2017)
- Fastest 1/4 mile @ 157,12 kph on flat and 14.468 sec (146V, 600A, Kelly KHB 14601, 2017)
- Fastest 1/4 Mile @ 170,62 kph and 12,278 seconds ( 117V, 800A, Emsiso EmDrive 500, 2018)
14/34kW QS-Motor 273 80H 7T winding (560A and 1740 turns @ 144V) @ 169kg GSXR 1000 K2
Rovii   1 kW
Post by Rovii » Mar 05 2020 3:43am
Got some little LED stripes for the bike
Andre
Rovii   1 kW
Post by Rovii » Mar 12 2020 2:20am
Thanks Corona,
Energy fair was shifted now from end of March to middle of September.
So get some more to time :wink:
Andre
John in CR   100 GW
Post by John in CR » Mar 13 2020 8:55am
With so many electric cars in Europe, I've gotta believe that the best source for high quality and high power cells for a reasonable price has to be the salvage market. eg The Chevy Volt modules and Panasonic 26ah cells with threaded terminals, that I've purchases in the past several years have been incredibly powerful along with extremely high quality due to automakers over-engineered approach to electrics. Sure you may be able to get drag-race powered cells for an extreme premium, but for just a few kg more of weight that includes drastically greater capacity, automotive grade batteries can be a source for very high quality cells with already proven cell matching and already proven cell connections.
Rovii   1 kW
Post by Rovii » Mar 17 2020 8:15am
The only used battery you can get here in GER is an TESLA 6S 240Ah battery for 1000€.
And the weight of one battery is 25kg ...
Andre
John in CR   100 GW
Post by John in CR » Mar 20 2020 8:31pm
Rovii wrote:
Mar 17 2020 8:15am
Someone is getting the batteries from all the wrecked cars. Tesla cells won't cut it for a drag bike. They just aren't powerful enough. Too bad so little info is available regarding batteries in hybrids. Those much smaller packs could be an ideal source of very economical batteries to meet your needs, because many are designed for quite high power but relatively low total energy. Salavaged packs from hybrids are super cheap in the US, because they don't match the needs for aftermarket use due to high power density but low energy density. eg We picked up a complete 96s pack from a Hyundai hybrid for only $300.
Rovii   1 kW
Post by Rovii » Mar 23 2020 2:23am
That´s really cheap!
In the meanwhile stand still regarding covid-19 in my project I asssited my brother by doing some electrical work on his combustion bike. No key neccessary to start up the bike anymore:
[youtube]LoL0ewKsdhs[/youtube]
Andre
Rovii   1 kW
Post by Rovii » Mar 26 2020 8:02am
Got a second LED set and combined it ...
[youtube]TK0mFlDnZkk[/youtube]
Andre
Rovii   1 kW
Post by Rovii » Apr 28 2020 12:42am
The sprocket seems to be ready now …
But the motor STP-file I got does not fit for 100%, there is a 1/10 bis 3/10 gap :cry:
So we have to do the cut out again.
Andre
SlowCo   1 MW
Post by SlowCo » Apr 28 2020 4:59am
Rovii wrote:
Apr 28 2020 12:42am
The tooth profile seems to be incorrect and/or too large. How were the splines made? Laser cut, CNC ground or else? Because the way the splines are cut can have an impact on the profile and dimensions.
Rovii   1 kW
Post by Rovii » Apr 28 2020 12:31pm
The cut out was made by EDM machine with a super small core (2/10mm). So the machine was not the problem. It’s really the STP-file I got. The axle inside the file is smaller than the measured value.
We will get a second chance.
So hopefully the motor holding plates will be ok ...
Maybe I see it on Friday!
Andre
Rovii   1 kW
Post by Rovii » Apr 29 2020 8:21am
Well, I hope the rest of the work will be ok ...
Andre
Rovii   1 kW
Post by Rovii » Apr 30 2020 10:20pm
That’s the plan ...
Andre
Rovii   1 kW
Post by Rovii » May 06 2020 1:17am
Plates were cuttet and first plate is also temporary mounted.
Andre
Rovii   1 kW
Post by Rovii » May 08 2020 5:40am
Now both plates were temporary inside and must be adjust ...
Andre
Rovii   1 kW
Post by Rovii » Jun 15 2020 12:15pm
Motor is adjusted. Only some minor things to handle ...
Next step will be the the sprocket and controller ...
Andre
Rovii   1 kW
Post by Rovii » Jun 18 2020 3:25am
... the controller is now also fixed ...
Andre
Rovii   1 kW
Post by Rovii » Jun 25 2020 12:30am
Get the first shape of the fake fuel tank cover
Andre
Rovii   1 kW
Post by Rovii » Jun 29 2020 2:38am
Short movie:
https://youtu.be/cOCe_BNfDbc[
youtube]cOCe_BNfDbc[/youtube]
Andre
Rovii   1 kW
Post by Rovii » Jul 03 2020 12:57am
Water return from motor and controller to the radiator is ready installed.
But for the feed from radiator over the peltier elements and pumps to motor and controler is much heavier to realise and needs some special equipment.
Andre
Rovii   1 kW
Post by Rovii » Jul 11 2020 2:18am
Actual status of the electrical motorcycle
[youtube]1DaTNSqNQ2E[/youtube]
Andre
Frank   100 W
Post by Frank » Jul 11 2020 6:49am
Is the front-end strapped down or something? There appears to be only very small travel of the forks before they would bottom out.
Frank
Rovii   1 kW
Post by Rovii » Jul 12 2020 12:11am
No, it’s not strapped down, it’s shortened to 55mm suspension length. Rules said 25 to 45mm is necessary.
Therefore I am in line. That bike is not a daily!
But I am able to lift it up a little bit by less spring preload.
Andre
Rovii   1 kW
Post by Rovii » Sep 15 2020 12:08am
- Cooler is fixed
- Sproket is fixed
- Part of front fairing is done
Andre
Rovii   1 kW
Post by Rovii » Oct 04 2020 10:49pm
Starting with the cabling ...
Andre
