Suzuki GSX-R e899 K2
Show off your E-Scooter or Motorcycle creation here.
parabellum   10 MW
Re: Suzuki GSX-R e899 K2
Post by parabellum » Aug 22 2018 10:49pm
Rovii wrote:
Aug 20 2018 1:05am
Well I use the time in between to sattle new top speed records with my second toy :
Nice. Do you have a video someone filming you riding? I just can not understand how it could work in sitting position.
Rovii   100 W
Post by Rovii » Aug 22 2018 11:17pm
I have only this very old one during building process:
https://youtu.be/i80VAPQzcYA
Btw I have decided me now for my next controller:
Scott Drive‘s SD300
But I can order him earliest in October when motor manufacturer has finished their tests.
- Fastest speed record 200,49 kph on flat after 740m (175V, 400A, Kelly KLS 8080I 14401, 2017)
- Fastest 1/4 mile @ 157,12 kph on flat and 14.468 sec (146V, 600A, Kelly KHB 14601, 2017)
- Fastest 1/4 Mile @ 170,62 kph and 12,278 seconds ( 117V, 800A, Emsiso EmDrive 500, 2018)
14/34kW QS-Motor 273 80H 7T winding (560A and 1740 turns @ 144V) @ 169kg GSXR 1000 K2
Rovii   100 W
Post by Rovii » Sep 06 2018 3:22am
I will design now the swing arm of my own.
Start first by the extensions
Rovii   100 W
Post by Rovii » Sep 16 2018 11:34pm
Prepared already the swing arm ...
Rovii   100 W
Post by Rovii » Sep 27 2018 2:11am
My new rear suspension from M2 Shocks Type S2 reached me yesterday ...
Rovii   100 W
Post by Rovii » Oct 02 2018 6:52am
In Progress ....
Rovii   100 W
Post by Rovii » Oct 04 2018 11:26pm
Extensions are ready for transplantation ...
SlowCo   100 kW
Post by SlowCo » Oct 05 2018 3:59am
How much torque and power are you expecting to need longer extensions? They seem longer than a 400kW turbo Hayabusa needs... :shock:
Rovii   100 W
Post by Rovii » Oct 05 2018 4:26am
Well the max wheel base is 12" over.
It´s also a little bit longer as a design issue!
I will never reach 400kW cause of battery pack size and weight!
Torque, I also don´t know that´s depending on transmission ratio but I think over 1000Nm could be possible at rear wheel. But I also don´t know how much Nm has a 400kW turbo hayabusa in 1st gear. They measure their 300-350Nm mostly in 5th or 6th gear on dyno.
And I have learned that the lengths of extension depends on the track conditions!
Slippery = shorter
Sticky = longer
Rovii   100 W
Post by Rovii » Oct 14 2018 11:24pm
Well, hopefully I got the swing arm (Phase 1) back in two weeks ...
Rovii   100 W
Post by Rovii » Oct 24 2018 11:38pm
There is so much space at left handle bar that I decided to mount a hydraulic clutch from Suzuki GSXR 1100 W model.
Rovii   100 W
Post by Rovii » Oct 29 2018 1:55am
Phase One is done ...
Swingarm 042.JPG (141.9 KiB) Viewed 2043 times
Rovii   100 W
Post by Rovii » Oct 30 2018 7:32am
Got it in already and also out for next step (underbracing)
Swingarm 038.JPG (139.36 KiB) Viewed 2021 times
Swingarm 042.JPG (141.9 KiB) Viewed 2021 times
Rovii   100 W
Post by Rovii » Oct 31 2018 12:26am
The chain adjuster are also ready.
Waiting now on a special holder for the rear suspension reservoir and for a clutch hydraulic reservoir cover then it can be colored.
Rovii   100 W
Post by Rovii » Nov 07 2018 12:52am
Even to the point that you get boring ...
Blue clutch lever for 11W armature arrived and due to the fact that I plan in future to go over 100kW, I decided myself to order a second front brake disc.
Schwinge 055.JPG (137.09 KiB) Viewed 1926 times
Schwinge 053.JPG (131.9 KiB) Viewed 1926 times
Rovii   100 W
Post by Rovii » Nov 12 2018 1:27am
Add now the second brake disc ...
Rovii   100 W
Post by Rovii » Nov 15 2018 5:41am
Shorten now the rear tail ...
Rovii   100 W
Post by Rovii » Nov 19 2018 4:12am
without any words ...
macribs   1 GW
1 GW
Post by macribs » Nov 19 2018 7:22am
Dang that thing looks mean and angry :thumb:
Rovii   100 W
Post by Rovii » Nov 29 2018 2:27am
Got a new blue colored voltage display. Should be able to show up to 999V!
First battery (23V) = ok,
second battery in series (6S+4S, 37V) = ok,
third battery (4S) in series with others = dark display :(
After short discussion we came to the point, that I will get a new one now (maybe in one month) ...
liveforphysics   100 GW
Post by liveforphysics » Nov 29 2018 3:14pm
Beautiful bike!
Rovii   100 W
Post by Rovii » Nov 30 2018 2:38am
Thanks macribs and Luke!
But it´s not yet finished because I want to lower also the seat position.
Here is my last sketch regarding a possible look.
At first I want to start by building a wood frame for the seat position and test it.
Well to be honest I use this motorcycle only for quatermile and normaly it should be possible to use a bicycle seat :lol: but I have to find the right solution/look not to destroy the overall design of the motorcycle!
Rovii   100 W
Post by Rovii » Dec 04 2018 4:20am
Already starting to update die seat position (-4") ...
Rovii   100 W
Post by Rovii » Dec 05 2018 1:35am
And cut the first mount of rear frame ...
Rovii   100 W
Post by Rovii » Dec 12 2018 12:58am
Got now my suspension holder
