Suzuki GSX-R e899 K2
Show off your E-Scooter or Motorcycle creation here.
Rovii   1 kW
Re: Suzuki GSX-R e899 K2
Post by Rovii » Oct 22 2020 5:51am
Cabling is near to finish.
Starting now with parameterisation ...
Andre
- Fastest speed record 200,49 kph on flat after 740m (175V, 400A, Kelly KLS 8080I 14401, 2017)
- Fastest 1/4 mile @ 157,12 kph on flat and 14.468 sec (146V, 600A, Kelly KHB 14601, 2017)
- Fastest 1/4 Mile @ 170,62 kph and 12,278 seconds ( 117V, 800A, Emsiso EmDrive 500, 2018)
14/34kW QS-Motor 273 80H 7T winding (560A and 1740 turns @ 144V) @ 169kg GSXR 1000 K2
Rovii   1 kW
Post by Rovii » Oct 23 2020 2:44pm
So it’s alive ...
[youtube]_px04JXn2i8[/youtube]
Andre
Frank   100 W
Post by Frank » Oct 23 2020 3:45pm
Congratulations - that is a big step!
Frank
Rovii   1 kW
Post by Rovii » Oct 26 2020 12:32am
Thanks Frank,
yes I was so happy to get it working!
In meantime I also did now the atomatic resolver tuning and the offset went from 0 to -127
So next steps will be to build the battery boxes and some minor stuff.
Andre
Rovii   1 kW
Post by Rovii » Nov 18 2020 6:25am
Met the Taycan 4S.
An absolutely fantastic car in performance and cornering.
Andre
Rovii   1 kW
Post by Rovii » Nov 30 2020 12:42pm
Made now the first ride ... only at 30A phase current but that was enough for cruising at 125VDC.
I calculated 60 kph at no load and reached 40,9 kph at the end.
Andre
Haggan90   1 mW
Post by Haggan90 » Dec 02 2020 4:28am
Hi Andre (nice name btw)
What's your current spec on motor and controller?
Rovii   1 kW
Post by Rovii » Dec 02 2020 9:13pm
Thanks,
Well the motor is from Phi Power AG. It’s a PhE381 with 200kW peak power for 20 seconds, 6000 rpm and 640Nm of torque.
The controller is from Scott Drive. Model SD300. Operating with max of 800VDC and forwarding up to 600ARMS phase current to the motor, so the type of model is listed with 400kVA and already tested with 340kW output power in combination with a Remy HV250 on a test bench by manufacturer.
I will start slowly with the power by increasing current and voltage step by step.
Andre
Rovii   1 kW
Post by Rovii » Dec 04 2020 8:06pm
Check out the video clip:
[youtube] https://www.youtube.com/watch?v=61hLdsg ... ture=share[/youtube]
Andre
SlowCo   1 MW
Post by SlowCo » Dec 05 2020 2:23pm
Rovii   1 kW
Post by Rovii » Aug 17 2021 12:13am
A long time you don’t hear something about my actually status.
There are still some tiny open points to manage.
E. g. I got now the right controller software to start with higher current runs and I successfully installed it
But before I start with this tests I will rebuild the bike ….
Andre
Rovii   1 kW
Post by Rovii » Oct 06 2021 7:46am
Andre
Rovii   1 kW
Post by Rovii » Oct 07 2021 9:16am
Totally dissembled!
Andre
Frank   100 W
Post by Frank » Oct 07 2021 9:23am
Why?
Frank
Rovii   1 kW
Post by Rovii » Oct 07 2021 10:04am
Rust at the Steel adapter plates and the frame need some welding and color …
Andre
Merlin   10 MW
Post by Merlin » Oct 07 2021 10:05am
will that thing ever see a dragstrip? ^^
Rovii   1 kW
Post by Rovii » Oct 07 2021 11:20am
Next year, why?
Andre
Rovii   1 kW
Post by Rovii » Oct 09 2021 6:09am
Now the rest is welded and can be forward to the painter by next week …
Andre
Rovii   1 kW
Post by Rovii » Oct 11 2021 10:30pm
Got already back the battery boxes …
Andre
Rovii   1 kW
Post by Rovii » Oct 14 2021 10:34am
The motor will also be colored a little bit by myself :lol:
Andre
Rovii   1 kW
Post by Rovii » Oct 15 2021 8:04am
Finished 8)
Andre
