My Chinese Ebay Build
Show off your E-Scooter or Motorcycle creation here.
kneedeep   100 W
Re: My Chinese Ebay Build
Post by kneedeep » Mar 31 2017 9:59am
kneedeep wrote:So the 19" is on its way has been shipped. I have talked to the seller an at a discounted price I might just keep the 17" for some future project. The shock I ordered was to long so I made a ride height adjuster and this will help once the 19" is on the back. should have more pictures this weekend. Also have the mounts for the headlight installed and to make a bracket to tie it all together. Getting much closer.
Looks like the 19" has not been shipped emailed Tuesday for a tracking # he said would get back to me tomorrow( Wednesday ) today Friday still no word. I originally ordered march 1st.
Chinese Ebay build in progress https://endless-sphere.com/forums/viewt ... 12&t=86149 , been through half a dozen scooter ebikes..No More of those.
I like to build it better than I can buy it. I like to think outside the box...Come to think of it where is that box?
kneedeep   100 W
Post by kneedeep » Apr 04 2017 10:37pm
well still no front wheel yet but my battery is in the country should see by Monday. :P
kneedeep   100 W
Post by kneedeep » Apr 05 2017 9:55am
New wheel arrived 19" front moto with 20mm through axle. Aesthetics are great but the spokes are too long at some points. Every 4th spoke has up to 4mm hangout. so I will have to knock the hangout off each one with a dremmel tool. Offset looks perfect wheel is true. I will assemble on the weekend.
kneedeep   100 W
Post by kneedeep » Apr 06 2017 10:42am
Front lights mock up. I decided to turn the mounts in for cleaner look. I like it. :mrgreen:
joe81   100 W
Post by joe81 » Apr 07 2017 10:45am
very curious how that frame performs off road. considering it myself.
kneedeep   100 W
Post by kneedeep » Apr 07 2017 10:47am
joe81 wrote:very curious how that frame performs off road. considering it myself.
I honestly have no idea I have never even road a bike with this style fork yet. This bike will not see to much off road or anything hard core.
kneedeep   100 W
Post by kneedeep » Apr 09 2017 12:30pm
Sorry for some reason I read fork. The frame looks solid as far as construction, it is heavy. The paint on my frame looks to be just powder coat and not too durable it chips easy, I foresee lots of delamination. Next winter after first season I will epoxy prime and paint.
kneedeep   100 W
Post by kneedeep » Apr 09 2017 12:39pm
Headlight mount painted and installed. It has a slight twist in it you will see, it will be half that after mounted but slightly toward ditch so will not blind cars or other bikes while on the road. Aluminium yard stick is great cheap material to work with.
kneedeep   100 W
Post by kneedeep » Apr 10 2017 10:51pm
I will have to dim the light. It is stupid bright and will blind people for sure.
kneedeep   100 W
Post by kneedeep » Apr 13 2017 12:28am
Battery has arrived. Dimensions are much bigger than described might be able to make it work. We are in deliberations of what is going to happen. :cry:
Wind82   100 µW
100 µW
Post by Wind82 » Apr 13 2017 10:43pm
I have a Chinese frame that is almost the same even the color , the only difference i see is my key is on the side and not the top. I got it on sale for 375 shipped with a burner rcp3 shock .
Can you tell me what adapter you need to mount the rear disk brake caliper to the frame ? This is pretty much all i need to be able to finish my test build .
kneedeep   100 W
Post by kneedeep » Apr 13 2017 11:15pm
these 2 combined.
kneedeep   100 W
Post by kneedeep » Apr 13 2017 11:16pm
this
kneedeep   100 W
Post by kneedeep » Apr 18 2017 11:36pm
kneedeep wrote:Battery has arrived. Dimensions are much bigger than described might be able to make it work. We are in deliberations of what is going to happen. :cry:
Ended up with partial refund and will reconfigure the battery slightly (move BMS and package different) have to test a couple cells as voltage is not correct (54V) will test BMS and replace if needed. I have a few better BMS on hand if needed.
kneedeep   100 W
Post by kneedeep » Apr 19 2017 12:19am
so tis is what I found in the pack 4p16s so my math says its a 20AH not a 25AH so out of 5 AH right off the bat. will test each set of cells tomorrow.
parabellum   10 MW
Post by parabellum » Apr 19 2017 11:11am
kneedeep wrote:so tis is what I found in the pack 4p16s so my math says its a 20AH not a 25AH so out of 5 AH right off the bat. will test each set of cells tomorrow.
Why did you decided for LiFePO4 cells?
Can you see any inscription on the cells metal body, underneath shrink wrap?
kneedeep   100 W
Post by kneedeep » Apr 19 2017 10:33pm
I have only known LiFePO4 in the past and am only still learning about other cells.
smeagol222   100 W
Post by smeagol222 » Apr 20 2017 11:55am
I think 18650 are the a favorite. They're lighter etc.
There's probably some way to work this out with a formula, but I was thinking the other day. Comparing the Ah cost between lifepo4 and 18650 li-ion.
If you charged 18650 pack to 80% or 4v per cell instead of 4.2v I think you'd get nearly the same, or more charge cycles than lifepo4?
Then all you'd have to do is build a pack 20% more cells than you need, then always charge to 80%. Surely that would still be cheaper than lifepo4
Just something I was contemplating
First project small E-scooter upgrade 1.5kw/3kw 48v 45a https://endless-sphere.com/forums/viewt ... 12&t=86228
Current project medium E-scooter upgrade 4kw/7kw 72v 90a https://endless-sphere.com/forums/viewt ... 10&t=85164
joe81   100 W
Post by joe81 » Apr 25 2017 6:24pm
kneedeep wrote:New wheel arrived 19" front moto with 20mm through axle. Aesthetics are great but the spokes are too long at some points. Every 4th spoke has up to 4mm hangout. so I will have to knock the hangout off each one with a dremmel tool. Offset looks perfect wheel is true. I will assemble on the weekend.
seems like they miscalculated spoke length. angle and lacing pattern don't look healthy to me
kneedeep   100 W
Post by kneedeep » Apr 25 2017 10:32pm
Closer inspection has shown the same length spokes and a dished rim to give true center. The spokes are alternated in and out on the spindle. On the dished side the inward spoke on the spindle is reaching through the nipple. this being every 4th spoke looks long. With this I am fine trimming that spoke. I have not had time to work on this the last few weeks but should have it mobile by end of the week.
kneedeep   100 W
Post by kneedeep » Apr 28 2017 1:30am
Almost done. I am finishing up the last of the wiring but the key switch I think is going to be a problem. This hub internal controller has the key switching full amps not just a controller signal. I cannot see the switch handling the amps (30amp max) very well. Your thoughts?
dirkdiggler   10 kW
Post by dirkdiggler » Apr 28 2017 3:46pm
Why did you need to adjust the shock height? When you sit on the bike it will sag. Was it still too tall for you?
kneedeep   100 W
Post by kneedeep » Apr 28 2017 10:04pm
dirkdiggler wrote:Why did you need to adjust the shock height? When you sit on the bike it will sag. Was it still too tall for you?
I ordered the wrong one it was too long. I will ride it for a bit, set it up to where I want it then order correct one.
kneedeep   100 W
Post by kneedeep » Apr 30 2017 9:52pm
Loads done this weekend. Brakes 100% complete and work great, battery fitted tight but great fit has no room to move around.
Wires have been cleaned up ( I had to put a fork bag below the headlight for wires as all the connections reached about that area and I did not want to splice every feed). I just have to install connectors on all the wire ends so it is easily serviceable.
I was having trouble with chain alignment because I was using a 135mm drop out motor in the 155mm drop out bike. I was looking at a new BB spindle (currently a 147mm) till I found a crank set with 10mm extra offset in my scrap pile, now the chain runs true. If this crank set works well I will look for a new one similar.
The crank that worked awesome is an EXAGE 300 LX with a biopace-sg. So at some point I will be looking for these parts in as new or new condition. I will have to research them.
I was on the fence how I was going to do my tail lights then I seen the CyklonEbike post on Facebook and I am going that route as I had those lights on the shelf from building trailers.
I would like to sort out a 48volt activated relay to switch the brake lights via the brake cut outs. Any ideas on that would be great.
kneedeep   100 W
Post by kneedeep » Apr 30 2017 10:14pm
I will try this for the brake light. Will see what the delay is when set up, it is cheap to try. http://www.ebay.ca/itm/Mini-DC-DC-Conve ... SwjDZYZgNI
