Derbi senda with hacker motor
Show off your E-Scooter or Motorcycle creation here.
bionicon   1 kW
Post by bionicon » Jun 09 2017 2:41pm
Hello everybody I want to share my latest project. Its not finisched yet but i have already 9 hours of drive-fun:) :D
Its made out a derbi senda with alu-frame adjusted to adapt the new motor and batterybox. The motor is the hacker Q150 -45 with 71 rpm/volt, a 14s lippo battery with 5kwh capacity. It works with the the hacker hst350 controller ,totall weight is about 85kg.
Till now its the most fast electric bike i ever did drive it hauls like crazy and cannot give full trottle yet(some settings must be adjusted.) Before i played with the idea to put that motor on a bicycle, but now it scares me :lol: I will make a short video soon, here some pics of the building:
endless 20.jpg (193.32 KiB) Viewed 4519 times
endless 18.jpg (239.96 KiB) Viewed 4519 times
endless 17.jpg (232.9 KiB) Viewed 4519 times
endless 16.jpg (220.91 KiB) Viewed 4519 times
endless 13.jpg (200.03 KiB) Viewed 4519 times
endless 12.jpg (239.23 KiB) Viewed 4519 times
endless 9.jpg (241.67 KiB) Viewed 4519 times
endless 8.jpg (194.43 KiB) Viewed 4519 times
endless 7.jpg (180.22 KiB) Viewed 4519 times
endless 5.jpg (212.76 KiB) Viewed 4519 times
endless 1.jpg (73.06 KiB) Viewed 5596 times
endless 2.jpg (28.04 KiB) Viewed 6649 times
macribs   1.21 GW
1.21 GW
Re: Derbi senda with hacker motor
Post by macribs » Jun 09 2017 10:15pm
Cool to see the build process. As I said before. Fantastic build. I think you have a very special motor and controller combo. Insane power yet light as a feather.
Look forward to see videos.
jonnydrive   100 W
Post by jonnydrive » Aug 04 2017 10:08am
Wow!
simply awesome!
gogo   10 MW
Post by gogo » Aug 04 2017 5:14pm
Looks fun. You might want to monitor for heat from eddy currents where the rotating motor magnets are close to the frame.
"A conclusion is the place where you got tired of thinking." -Steven Wright
litespeed   100 kW
Post by litespeed » Aug 05 2017 8:18am
Excellent job and I'm also looking forward to video.
Tom
madin88   1 GW
1 GW
Post by madin88 » Aug 06 2017 7:57am
Great conversion^^
the "motor box" is a good idea to give that motor protection against dirt and water.
does the rotor show magnetism on the outside? if no, than there should not be a problem with additional losses as mentioned before.
there is almost nothing available about the haker stuff in the internet and you are the only person in ES i know who runs such drive system. please keep us updated.
- 10kW belt drive with Neumotor 8057: [url]viewtopic.php?
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
bionicon   1 kW
Post by bionicon » Aug 06 2017 2:54pm
thx everybody for the nice comments, gonna try to make a short video next weekend. Just finished a long weekend at the sea with the bike :D I did ride it everyday and the longest trip was arround 120km long(cell voltage was then 3.7 volt so not empty yet) this at a average speed of 40km/h.Top speed is arround 85km/h.
It has not the wheely -torque at take-of but accelerate fast, I will try to capture that with a video :lol:
macribs   1.21 GW
1.21 GW
Post by macribs » Aug 06 2017 6:12pm
Video. Nice. Your build is so clean and uncluttered. Really nice craftsmanship. And that color just makes it all look even better. Seems factory build.
bionicon   1 kW
Post by bionicon » Aug 20 2017 11:15am
Here is a short video ,the only thing i am missing a bit is the starting-torque maybe i can get this better with adjustment the controller :wink:
https://www.youtube.com/watch?v=d05nyf3hOo8
TomBe   1 µW
Post by TomBe » Oct 26 2017 1:00pm
Carl, this is awsome work!
I am realy excited reading your posts.
I also have custom motorbike but I used revolt motor.
Are you able to make some photos, showing front sprocket and whole chain transmision?
What is the distance betwen axle of the motor and axle of the swingarm?
bionicon   1 kW
Post by bionicon » Oct 28 2017 12:05pm
tombe, pm send
madin88   1 GW
1 GW
Post by madin88 » Oct 29 2017 5:15am
I took the Hacker Q100 (38mm stator) on the shortlist for a middrive setup.
The problem (aside from the price :) ) i see is there is no axle coming out on the backside where a sprocket can be mounted to.
bionicon, how did you manage to install such on your Q150? On one photo i can see a small solid axle with another bearing.
A few more pics would be nice to see.
and how do you like the HST controller?
The small Herkules 5 seems to be AWESEOM from the specs. True FOC 4-quadrant control, hall sensor input etc etc. What a nice 2kW+ controller, but certainly out of my budget...
bionicon   1 kW
Post by bionicon » Oct 29 2017 5:50am
Hey Madin, ik know the problem of the tiny axle it was first 8mm thick (too small) i drilled the 8mm to 12 mm thats better, but not the best solution i know .(the axle is at two places fasten with m8 screws and because i use regenaration also the power direction is at two sides whats hard on the screws)
This winter i gonna change direction of the motor and use the other side (there is also good bearing and it work like an inrunner)and use a 19mm axle direct bolt on the motor, maybe i use another extra bearing for support.
bionicon   1 kW
Post by bionicon » Oct 29 2017 6:25am
20170417_154011 (1)_LI.jpg (115.22 KiB) Viewed 4504 times
This is a picture of the 8mm axle
madin88   1 GW
1 GW
Post by madin88 » Oct 29 2017 1:05pm
8mm axle is truly a problem, and from the pics it looks like it has no support where it comes out of the motor.
https://www.hacker-motor-shop.com/hacke ... 89_b_2.JPG
It is an axle in an hollow axle which is only meant to center the prop think.
hmm..
If you would mount the motor backwards i guess you would need to change the mounting bracket and fabricate a bolt-on axle with additional support (similar as you did with the 8mm axle).
have you thought about fabricating an axle and attach it backwards to the prop adapter with a tight fit into the hollow shaft:
similar as Neu Motor offers for the 8057 type:
I would do it like this on the Q100.
bionicon   1 kW
Post by bionicon » Oct 30 2017 2:20am
You can mount an custom axle at the propside thats what i am planning to do.Maybe supported with an extra bearing.
bionicon   1 kW
Post by bionicon » Feb 28 2018 11:19am
mounted axle on the propside
bionicon   1 kW
Post by bionicon » Mar 23 2018 9:19am
Hi i am trying to set my controller right , trying to get more startpower (wheelypower:))
Can anybody look at the screenshots i took, and tell me what i must change?
madin88   1 GW
1 GW
Post by madin88 » Mar 23 2018 9:34am
bionicon wrote:
Mar 23 2018 9:19am
I believe nobody here aside from you has experience with these Hacker controllers.
Don't they offer support?
bionicon   1 kW
Post by bionicon » Mar 23 2018 9:45am
madin88 wrote:
Mar 23 2018 9:34am
bionicon wrote:
Mar 23 2018 9:19am
Yes the support is great ,
and have already used it several times, but do not want to bother them too much.Also i want to learn it myself.
bionicon   1 kW
Post by bionicon » Mar 23 2018 12:22pm
can somebody maybe explain line 27 and 28 of the list? Thx
neptronix   100 GW
Post by neptronix » May 24 2019 3:34pm
How'd the build go?
flat tire   1 MW
Post by flat tire » May 24 2019 6:54pm
bionicon wrote:
Mar 23 2018 12:22pm
27 would be change in amps per pwm cycle and 28 would be the duty cycle increase limit per cycle. That's my guess anyway.
bionicon   1 kW
Post by bionicon » May 25 2019 11:09am
flat tire wrote:
May 24 2019 6:54pm
bionicon wrote:
Mar 23 2018 12:22pm
Thx, already changed motor and controller , now its a qs 138 motor 3000w and a sabvoton 72200 controller,this combo gives me way more torque :D
tylerwatts   100 W
Post by tylerwatts » Feb 18 2020 6:01pm
Do you have a thread with the new motor please?
Cheers
Tyler
