Ultrasonic tab welding
Postby Inwo » Thu Oct 12, 2017 5:46 pm
Thinking of acquiring a welder for aluminum lto pouch tabs.
Anyone have information or sources.
Found one for $3500 from China. Fits my budget if it works. I don't know what to look for.
Inwo
Re: Ultrasonic tab welding
Postby PaulD » Thu Oct 12, 2017 6:14 pm
I would recommend asking the welder vendor what materials and thicknesses the machine can weld. The little ones for welding current collector foils likely don't have the power to do thick tabs. Just as a reference point, I nearly maxed out a 1.5kw welder doing 3X 0.2mm copper tabs to 1.6mm copper busbar with large pads (maybe a 0.5in2 area) on the horn. Aluminum to copper required about 75% of the power.
If you are just doing aluminum to aluminum, less power is needed. The vendor should be able to tell you.
PaulD
Postby 999zip999 » Thu Oct 12, 2017 6:35 pm
What battery cells we talking about.?
999zip999
Postby Inwo » Thu Oct 12, 2017 7:28 pm
PaulD wrote:I would recommend asking the welder vendor what materials and thicknesses the machine can weld. The little ones for welding current collector foils likely don't have the power to do thick tabs. Just as a reference point, I nearly maxed out a 1.5kw welder doing 3X 0.2mm copper tabs to 1.6mm copper busbar with large pads (maybe a 0.5in2 area) on the horn. Aluminum to copper required about 75% of the power.
You have experience with ultrasonic welding? I'm starting from zero.
I'll get the specs. Means nothing to me!
Inwo
Postby Inwo » Thu Oct 12, 2017 7:37 pm
999zip999 wrote:What battery cells we talking about.?
11ah and 50ah titanate pouches. LTO
These were made for Altairnano by Kokam. 9 years old, but hey, LTO are forever!
Foil to foil only, but maybe several layers.
Only have a thousand or so 50ah, so will need to parallel the 11s for my uses. >100ah
Tabs may only reach to about 4p without bus bar of some kind.
Maybe I will need tab to cu welds.
Inwo
Postby Inwo » Thu Oct 12, 2017 7:38 pm
Maybe I need a partner with a welder?
:wink:
Inwo
Postby Inwo » Thu Oct 12, 2017 7:48 pm
Quick Details
Type: Other
Voltage: AC 110V or 220V +/-10%, 50/60Hz
Current: Request
Rated Capacity: 2000W
Rated Duty Cycle: Request
Dimensions: 360mm(L) x 480mm(W) x 200mm(H)
Weight: 60kg
Usage: Welding Machine
Certification: CE Certificate
After-sales Service Provided: Engineers available to service machinery overseas
Color: Request
Warranty: 1 Year, One Year limited warranty with lifetime support
Features: Preset welding programs selectable for Al and Cu
Welding Area: 4mm(L) x 4mm(W)
Welding Head: The welding heads and welding bases are included
Controller: 360mm(L) x 480mm(W) x 200mm(H)
Welder: 200mm(L) x 460mm(W) x 270mm(H)
Material: Steel
Ultrasonic Frequency: 40K Hz
Max. Welding Thickness: Max. 20 layers
Inwo
Postby PaulD » Fri Oct 13, 2017 12:21 pm
Cool. Looks like that might work. The machine I was referring to is $40K and doens't belong to me!
At 2000W, not sure how it could run off of 110V.
Inwo wrote:Quick Details
Type: Other
Current: Request
Weight: 60kg
Color: Request
Material: Steel
PaulD
Postby Inwo » Fri Oct 13, 2017 11:44 pm
Tnx, tempted to spend my battery money on it. Easy come easy go.
If it works, I could maybe get 1/2 price when I'm through with it.
Hate renting. Then I'd have to hustle. Like having a real job.
Inwo
Postby 999zip999 » Sat Oct 14, 2017 12:33 am
I guess 2,000 watts is 220v. Now the big question is how much ? Be nice to talk to someone who has one.
999zip999
Postby Inwo » Sat Oct 14, 2017 9:00 am
Exactly, I have know idea what I'd be getting into.
Inwo
Postby Inwo » Tue Oct 17, 2017 12:25 am
Found a $1500 handheld welder.
Last edited by Inwo on Tue Oct 17, 2017 9:58 pm, edited 2 times in total. View post history.
Inwo
Postby Inwo » Tue Oct 17, 2017 9:57 pm
Cheap way out for 800 watt handheld welder. Should be ok aluminum only. If it won't weld to cu bus, I'll bolt terminations.
Weld series connections only. I'd rather risk $1500 than $5000.
Think I could resell it if I want a bigger one later.
This will be my tuition payment.
Been there done that! :D
Inwo
Return to Battery Technology
Users browsing this forum: Bing [Bot], dirttorpedo, stevc and 11 guests
