Battery Advice Needed For Middle School Competition
DrkAngel   10 GW
10 GW
Re: Battery Advice Needed For Middle School Competition
Post by DrkAngel » Nov 06 2017 8:25am
Updated ... refined
1. Motor speed can be varied by voltage.
Effectively, a somewhat equivalent of gearing.
1a.Panels in series or parallel.
4 x 12V panels
12V 1 in series 4 parallel (1s4p) 20A 50rpm (no load speeds) for comparison purposes only
24V 2 in series 2 in parallel (2s2p) 10A 100rpm
48V 4 in series 1 in parallel 5A 200rpm
1b. Battery similarly. (180wh)
180Wh / 3.6V Lithium = 50Ah
50Ah / 24 cells @ 2.08Ah
2s12p 7.2V 24Ah 20rpm (no load speeds) for comparison purposes only
3s8p 10.8V 16Ah 30rpm
4s6p 14.4V 12Ah 40rpm
6s4p 21.6V 8Ah 60rpm
8s3p 28.8V 6Ah 80rpm
12s2p 43.2V 4Ah 120rpm
Please note:
Li-ion rated at 180Wh, discharged in 25min can output near 170Wh
SLA Sealed Lead Acid rated at 180Wh, discharged in 25min might output a pitiful 80Wh.
2. Watt-watt Hour meters are fairly accurate and inexpensive. If a throttle is used, maximum safe battery output can be regulated fairly precisely!
180wh x 60/25 min = 432w
Should maintain 400w+ battery output for 25 minutes
A little learning is a dangerous thing;
Drink deep, or taste not the Pierian spring:
There, shallow draughts intoxicate the brain,
And drinking largely, sobers us again.
I enjoy enlightening ... and enlivening the spirit of the innovators.
New & Improved - Acronym Definitions
Index - Homemade Battery Packs - Updated - November 2018
EBike Toolbox - Bargains! $
Endless Sphere Wiki - Lost?
BlueBell   10 W
Post by BlueBell » Nov 06 2017 2:44pm
Thanks DrkAngel.
I get the voltage/rpm vs amps relationship.
What motor would we purchase to reach that end in our case for our parameters?
When does amperage become an issue?
Controller? Yes we need throttle, spring loaded (dead-man throttle).
Any suggestions?
Interesting about the difference in batteries. So, lipo it is.
Any recommendations?
Watt-watt hour meters: Any model you would recommend?
FYI I have also started a thread in the electric boat section.
999zip999   100 GW
Post by 999zip999 » Nov 06 2017 10:18pm
How about a panko Fisher 3-phase dishwasher motor. At the junk yard or scrapper. There must be a lot of other examples where you can get a three phase motor.
DrkAngel   10 GW
10 GW
Post by DrkAngel » Nov 07 2017 12:46am
"Amps" supplies torque for pushing over large props.
Volts = speed
Amps = torque
Factors to consider:
Desired propeller rpm range?
Direct power, no controller, on solar is slightly more efficient.
Motors are most efficient near 70-80% of no load speed.
250 watt input from panels ≥ 225w (output) motor
400 watt input from batteries ≥ 375w (output) motor
Using voltage to emulate gearing, 750-1000w (output) motor might be desirable?
But I over volt 450w motor for 675w output.
Controllers, typically, have a low voltage limit and high voltage limit.
Unfortunately, I am more familiar with brush motors, so some other expert might have a good suggestion on motor-controller.
Volt Amp Watt meter
Also see -eBike Toolbox Bargains
BlueBell   10 W
Post by BlueBell » Nov 07 2017 2:14am
999zip999 wrote:How about a panko Fisher 3-phase dishwasher motor. At the junk yard or scrapper.
Interesting.
Why would you recommend it?
Thank you.
BlueBell   10 W
Post by BlueBell » Nov 07 2017 2:28am
DrkAngel wrote:"Amps" supplies torque for pushing over large props.
Volts = speed
Amps = torque
Yes, that seems correct as I understand it.
500 - 1000 RPM
So we should wire them all in parallel and simply have an on-off switch?
And to control the motor from batteries?
Okay, so what are you suggesting here in my case?
Okay, so what does that mean in our application?
Volt Amp Watt meter
DrkAngel   10 GW
10 GW
Post by DrkAngel » Nov 07 2017 9:40am
Oops, my bad, brushless motors can not connect directly to battery or panels, they do require controller at all times ... said I was a brush motor guy ...
Only found 1 motor controller near optimal, about 500rpm with 30V LVC (48V from panel, or battery, will sag under throttle, 30V allows substantial draw before Low voltage cutoff - safety disconnect.).
$169 500w 36-48V brushless motor-controller
There are lots of brushless motors, but most all are high rpm 1700-3200 etc.
Gear reduction seems only feasible option ... ?
500w gr.jpg (125.23 KiB) Viewed 778 times
999zip999   100 GW
Post by 999zip999 » Nov 07 2017 11:15am
I wasn't recommending that Pacific Motor I just mean that there are three phase Motors out there you can get your hands on for cheap.
As dark angel said it's the way it's wound for more torque more speed how many RPMs you want to run at what voltage all that Drk Angels stuff.
I edited my last post but regot to push send last night. What?
BlueBell   10 W
Post by BlueBell » Nov 07 2017 4:33pm
DrkAngel,
Wow, a geared motor, look at that, thank you.
So 30V LVC (whatever that means) we'd need 4 - 12V lipo's in series to compensate for sag under load.
It comes with a controller, sweet.
The meter you recommended earlier.
What can we do for a dead-man's-throttle?
Anything else I'm missing?
DrkAngel   10 GW
10 GW
Post by DrkAngel » Nov 07 2017 5:13pm
Any HALL twist or thumb throttle will work. Twist allows more precise control
Any of these Throttles, recommend against cheapest, or buy multiple and compare performance.
With end connector and reasonable length.
Can't think of anything else "needed".
999zip999   100 GW
Post by 999zip999 » Nov 07 2017 11:29pm
Dr Angel I read all your and try to hang on. Thanks Bro.
DrkAngel   10 GW
10 GW
Post by DrkAngel » Nov 08 2017 8:51am
30V LVC (Low Voltage Cutoff) disconnects power if battery, or power source drops below 30V, which is a standard safety for 36V Lithium battery.
With 48V solar panels, 30V will allow throttling maximal draw from panels, reduced voltage offset by substantial amps. Drawing down panel voltage increases panel output somewhat. Larger than needed wire gauge helps too.
Just keep voltage-throttle position above 30V to prevent power interrupt!
Brush motors have greater options and availability ... but with somewhat reduced efficiency.
BlueBell   10 W
Post by BlueBell » Nov 08 2017 11:25am
Thanks again DrkAngel.
Throttle link terrific.
Aren't we using 48V from 4-series lipo's?
So wouldn't the 30LVC be easily avoided?
Same with panels...?
I'm in so far over my head here it's ridiculous!
I think I'll move the battery closer to the motor to keep cable runs as short as possible.
The panels are already as close as possible.
Although they could be turned sideways to shorten the over-all run...
Hmmmmm...
BlueBell   10 W
Post by BlueBell » Nov 10 2017 1:40pm
DrkAngel wrote:30V LVC (Low Voltage Cutoff) disconnects power if battery, or power source drops below 30V, which is a standard safety for 36V Lithium battery.
Not clear where the 36 volt battery comes in.
Can you clarify?
Thanks again.
DrkAngel   10 GW
10 GW
Post by DrkAngel » Nov 10 2017 7:38pm
Motor-controller is 36V or 48V compatible.
With 48V battery, 30V LVC will allow extra battery drain for competition (1 time with risk of battery damage ...
With 48V panels, will allow maximal panel current extraction. Turn throttle till voltage sags near 30V for increased watt output. Important, especially in partial sun.
999zip999   100 GW
Post by 999zip999 » Nov 10 2017 9:42pm
13s × 4.2 = 54.6 v or 14s × 4.2v = 58.8v fully charged.
999zip999   100 GW
Post by 999zip999 » Nov 10 2017 10:50pm
DrAngle help me out 13s and how many ah equals 180 wh hr ? How about 14s ? Or what's the math ?
0r better to run 12s or 10s ?
DrkAngel   10 GW
10 GW
Post by DrkAngel » Nov 11 2017 7:27am
see post above
  • 180Wh ÷ 3.6V cells = 50Ah
  • 12s2p (2080mAh cells) 43.2V 2000 or 2050mAh
  • 13s2p (1923mAh cells) 46.8V
  • 14s2p (1785mAh cells) 50.4V best ... if available
  • 15s2p (1666mAh cells) 54V 1650mAh cells max recommended
  • 16s2p (1562mAh cells)57.6V
  • 180Wh ÷ 3.7V cells = 48.64Ah
  • 12s2p (2026mAh cells) 44.4V
  • 13s2p (1870mAh cells) 48.1V best ... if available
  • 14s2p (1737mAh cells) 51.8V
  • 15s2p (1621mAh cells) 55.5V 1600mAh cells max recommended
  • 16s2p (1529mAh cells) 59.2V
Depends on cell rating-capacity
12s2p with 2000mAh cells? easily available
Stick to good brand name cells!
Panasonic
Samsung
LG
Sanyo
BlueBell   10 W
Post by BlueBell » Nov 11 2017 10:45am
By cell rating do you mean the "C" value?
Any idea what this battery is going to weigh?
DrkAngel   10 GW
10 GW
Post by DrkAngel » Nov 11 2017 11:33am
BlueBell wrote:By cell rating do you mean the "C" value?
Rated as 3.6V or 3.7V = average discharge voltage over full discharge cycle.
BlueBell wrote:Any idea what this battery is going to weigh?
24 18650 cells = 2-2.5lbs.
BlueBell   10 W
Post by BlueBell » Nov 11 2017 11:44am
2 -2.5 pounds, nice!!
Helps make up for the 17 pound motor!
What can we use to charge the battery from the four panels?
On race day, we're not allowed any shore charging ( from 120v A/C ),
only what the panels will give us.
It ( along with the panels ) can be removed for the 25 minute, battery only heat.
DrkAngel   10 GW
10 GW
Post by DrkAngel » Nov 11 2017 12:43pm
BlueBell wrote:2 -2.5 pounds, nice!!
1. Charge w/AC before race day. Quality Lithium does not bleed energy.
12s Lithium - 12 x 4.2V = 50.4V
Hold checking for something! Looked for DC\\DC step-down converter but couldn't find one, yet. 2. If you monitor voltage, you can manually top off voltage directly from panels, if output is above 50.4V ... do not charge above 51.6V!!! Wattage from panels might be excessive for safe-proper charging?
Panel voltage will sag to near battery voltage when attached
Affordable quality 2000mAh cells look scarcer than I thought.
Bargain on Sona cells!
In 20 cell bricks, 2s10p
24 cells need 2 minimum, recommend 3, for 2 builds + spares. Better price on 5 or 10.
Charging 6s tools
1/2 in 2 stages
iMax B6 for charging - testing
Homemade battery packs Index page
Balance cable
999zip999   100 GW
Post by 999zip999 » Nov 11 2017 12:48pm
How about a samsung 35g ( I'm guesing) at 3500 mah and 20amp cell or so 12s 1p style. Now I have to investigate the biggest baddest 18650 cell. I get back to you. 180 watt hours is the hard part.
DrkAngel   10 GW
10 GW
Post by DrkAngel » Nov 11 2017 1:16pm
14 x 3.6V x 3.500Ah = 176.4Ah
50.4V 3.5Ah
Nearly perfect!
Should work nicely, maybe better, with 48V motor-controller.
2 x 1750mAh cells would sag much less and provide noticeably better efficiency.
BlueBell   10 W
Post by BlueBell » Nov 11 2017 2:15pm
This is fantastic guys, thank you.
I should have mentioned earlier, we have a $1000 budget for the project...
Batteries can get pricey...
